Home > Help Needed / General Tech Chat > Metro Front Wheel Studs
Does anyone know how long the front wheel studs are on a Metro? I'm guessing that they're slightly shorter than on a Mini as the flanges aren't as thick.
I can measure tonight if you like.
Do you just need the length of the stud sticking out of the hub or the whole lot?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I have a broken stud on my Metro flange so I was looking at getting a new one a while ago. 31mm stands out for some reason.
I'll have a search to check
On 30th Apr, 2010 Rod S said:
Gary's description is best
