| Home > General Chat > Turbo's | |||||||
![]() 99 Posts Member #: 8439 Advanced Member Romiley |
3rd Mar, 2010 at 06:11:35pm
Anyone know where to get a turbo off the internet for a gt 1275 engine also thinking of fitting a dump valve but a bit of a noob so was hoping for sum help and advice lol On 27th Apr, 2010 wolfie said:
and some chav will nick it to fit on there rat look saxo |
3rd Mar, 2010 at 10:49:27pm
SEARCH Edited by Paul R on 3rd Mar, 2010. Drives
3rd Mar, 2010 at 11:02:12pm
3rd Mar, 2010 at 11:04:59pm
http://www.owendevelopments.co.uk/ Isambard Kingdom Brunel said:
66 Posts Member #: 8258 Advanced Member |
4th Mar, 2010 at 08:58:09am
Your idea/dream of using a turbo etc on a 1275GT sounds good :)
4th Mar, 2010 at 09:36:18am
Laurence, that is a bit over the top. It has been proved that apart from the diff a mildly boosted A-series needs very little in the way of uprating. A bit of head work to drop the compression and away you go.
http://www.twin-turbo.co.uk
4th Mar, 2010 at 09:47:21am
I think that we need a simple chart that gives the level of mods required for a range of horsepower targets.
4th Mar, 2010 at 10:28:12am
That is a good idea Paul. We know that a good condition standard engine will make 100+ without much boost and be fairly relaiable and we know that 200+ needs real thought. But what about all those numbers in between? http://www.twin-turbo.co.uk
4th Mar, 2010 at 11:15:11am
cheers for the help guys
11th Mar, 2010 at 08:00:44pm
Sorry to drag up a week-old post, but I had to correct a few points...
On 4th Mar, 2010 Laurence said:
The compression ratio should be lowered so you can run sufficient boost to make a noticeable difference without melting a piston or breaking a con rod. No-one has broken a con-rod through boost. A 130hp turbo engine is a lot less stressful on rods than a 130hp nat-asp engine. On 4th Mar, 2010 Laurence said:
The flywheel should be lightened, the clutch plate uprated together with an uprated diaphragm. Uprated diaphram yes (go straight for a grey), but no need to lighten anything if you don't want to. On 17th Nov, 2014 Tom Fenton said:
11th Mar, 2010 at 09:27:07pm
I made a list of stuff that i want/aim to get;
11th Mar, 2010 at 09:31:41pm
what boost are you going to run?
11th Mar, 2010 at 09:44:31pm
11th Mar, 2010 at 09:51:50pm
I woudn't bother with the crank and spend your money on a decent set of forged pistons instead. Edited by matty on 11th Mar, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Mar, 2010 at 09:53:36pm
11th Mar, 2010 at 09:54:37pm
On 11th Mar, 2010 Ell said:
probably looking at 20-25? fair play.. not a road car then? |
11th Mar, 2010 at 09:57:26pm
What power are you aiming for? You most likely won't need that amount of boost, as 200bhp can be acheived with less than 20psi. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Mar, 2010 at 10:00:48pm
I was looking at a drag project but now looking at it more as a road car so probably will bring down the boost, i was looking for around 180bhp enough power to give me a kick from the back of the seat lol On 27th Apr, 2010 wolfie said:
11th Mar, 2010 at 10:01:28pm
depends on whos rollers matty ...lol
11th Mar, 2010 at 10:14:17pm
Best find another turbo. There are better options than the T3 these days.
11th Mar, 2010 at 10:16:44pm
I have been looking on ebay alot looking for a complete unit eg. manifold, plenium ect
12th Mar, 2010 at 08:40:01am
Hi Ell
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
12th Mar, 2010 at 08:42:58am
Good advice, Wolfie. TurboPhil's website is-
12th Mar, 2010 at 05:29:24pm
Thinking about this and have decided I am going to run a lower boost on a the 1098 engine that is already in the car, cheers for the link paul On 27th Apr, 2010 wolfie said:
