| Home > Wanted > crank? | |||||||
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
8th Mar, 2010 at 11:31:07am
hi guys i have a 1275 gt block wit metro turbo pistons, cam and rockers and an avonbar phase 2 head, but i need a crank? would a gt one do or will ii need to upgrade it? i currently have a t3/t4 hybrid charger but i tink its 2 big so i'm gonna get a t2 or equivalent, any advise would be appreciated as i only need a crank, also i'm from ireland! On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
8th Mar, 2010 at 11:45:42am
I have a standard GT one going spare, postage won't be cheap to Ireland though.
8th Mar, 2010 at 11:49:16am
sorry meant to say i have a gt one! but i was told it wont work cos it has to be hardened?? On 5th Jan, 2011 wolfie said:
8th Mar, 2010 at 11:54:15am
Standard crank should be fine. Not all Metro Turbos had hardened cranks.
8th Mar, 2010 at 11:57:51am
THANK YOU, i was told by a company that builds engines over here its needed! will start boltin it together so. i'll put up pics soon On 5th Jan, 2011 wolfie said:
8th Mar, 2010 at 12:47:58pm
isnt the gt crank a higher grade steel but the big ends dont have the radius in the corner witch can be a breaking point Yes i moved to the darkside |
8th Mar, 2010 at 01:06:39pm
i'm unsure? so it wont work? or i'll have to strenghten it? fit straps? On 5th Jan, 2011 wolfie said:
8th Mar, 2010 at 01:21:00pm
On 8th Mar, 2010 Brett said:
isnt the gt crank a higher grade steel but the big ends dont have the radius in the corner witch can be a breaking point Even if it is, it's revs that will kill a crank, not boost. I've never heard of anyone braking a crank, it'll be fine. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Mar, 2010 at 01:27:33pm
9th Mar, 2010 at 11:42:01am
was offered a hardened ine from a 1380 from a friend so will use that and keep my gt one as spare or visa versa..... On 5th Jan, 2011 wolfie said:
9th Mar, 2010 at 12:20:59pm
isnt the gt crank a higher grade steel but the big ends dont have the radius in the corner witch can be a breaking point As far as I know, all Mini cranks bar Cooper S are EN16T. The jury is still out on the Metro Turbo one. On 13th Jul, 2012 Ben H said:
9th Mar, 2010 at 08:36:16pm
I think the general verdict is standard cranks are fine On 19th Jan, 2010 wil_h said:
