Home > Help Needed / General Tech Chat > cant start engine after fuel over pressure?
jom
Member #: 6003
the engine was really easy to start before..but its afternoon when i was trying to start engine. some heavy thing was on the fuel return pipe, and the fuel pressue gauge went to over 15psi, because return fuel coudnt go through the pipe..after this i removed the thing on pipe, and pressure went to 4psi as normal.BUT ENGINE COULDNT START. no fuel in to cylinder.
Kean
Member #: 341
aka T2clubby
South Staffs
Are the plugs ok? they are probably soaking with fuel if the pressure went that high!
jom
Member #: 6003
the plugs were dry. it looks like no fuel?
perhaps a split in the regs diaphram if their was a restriction in the return?
jom
Member #: 6003
will it change fuel pressure? i have a pressure gauge between reg and carb. it says 4psi which same as before ,when i can start
Are you sure they are sparking though? Wet plugs can look dry but wont fire, stick them in the ht lead put them against a head stud or something and turn her over. Hold the plug with a pair of plyers though lol
jom
Member #: 6003
i made mistake yesterday. today.. i find the plugs is wet. and engine can start now..AND i find the battery voltage changing also affect the fueling. The reason should be the speed of the pump. so i set my reg when battery was 12v. and when its 13.5v engine become really different to start
battery voltage will make no difference to the pump, in terms of fuel seen at the carburettor.
Well..unless its like 1v or something silly.
As said the pump shouldnt change, unless your batt was really flat!
