| Home > Help Needed / General Tech Chat > How to install a boost gauge. | |||||||
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
9th Mar, 2010 at 07:49:10pm
Ok, really simple question - but I wanted to make sure I'm correct before I bugger up my inlet manifold.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
9th Mar, 2010 at 07:49:45pm
Yep ! :) |
9th Mar, 2010 at 08:07:32pm
Braw.
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
9th Mar, 2010 at 11:01:50pm
is it possible to get pic, exactly where to make whole and where it goes after?
Nothing special! |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
9th Mar, 2010 at 11:44:34pm
if your using a metro inlet then there should be a littl flat raised area,
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
10th Mar, 2010 at 07:51:34am
On our metro van we have used the old vauum take off in the banjo bolt for the servo pipe, but you can just make out the flat spot to the left under the servo hose.
10th Mar, 2010 at 08:54:28am
On 9th Mar, 2010 rubicon said:
if your using a metro inlet then there should be a littl flat raised area, i used this... I'm using a custom made manifold - so I'll need to drill and tap a port. On 10th Mar, 2010 apbellamy said:
On our metro van we have used the old vauum take off in the banjo bolt for the servo pipe, but you can just make out the flat spot to the left under the servo hose. ![]() Thanx for that - a picture paints a thousand words. Does anyone know if I need a fitting kit (pipe, take off ect) with this gauge? http://minispares.com/Product.aspx?ty=pb&p...016&title=TURBO BOOST GAUGE There doesn't seem to be one listed on Mini Spares website, but thought I'd check. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
10th Mar, 2010 at 09:29:52am
I bought one of those, but from a trader at a show as new unused. It came with just the gauge. We needed to find a fitting for the manifold and a length of vacuum hose to connect it. On 11th Feb, 2015 robert said:
10th Mar, 2010 at 11:59:43am
I bought one of those, but from a trader at a show as new unused. It came with just the gauge. We needed to find a fitting for the manifold and a length of vacuum hose to connect it. Hmmm. I take it that it would be feasable to use a brake caliper bleed nipple, just cut to suit? "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
1050 Posts Member #: 764 Post Whore Staffordshire |
10th Mar, 2010 at 12:37:39pm
That's exactly what I did... workd fine |
10th Mar, 2010 at 01:08:38pm
The fitting in that pic cost about £2 delivered. On 11th Feb, 2015 robert said:
10th Mar, 2010 at 01:51:24pm
Same as i use on mine http://www.minispares.com/Product.aspx?ty=...476&title=UNION STRAIGHT 1/4 |
10th Mar, 2010 at 03:18:59pm
On 10th Mar, 2010 gavin@minispares.com said:
Same as i use on mine http://www.minispares.com/Product.aspx?ty=...476&title=UNION STRAIGHT 1/4 Grand. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
