| Home > Technical Chat > Blocking filter head bypass - sensible? | |||||||
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
11th Mar, 2010 at 12:34:24pm
Hi!
[X] nail here for new monitor |
11th Mar, 2010 at 12:40:46pm
Block it up, some use a grub screw, i welded mine I seriously doubt it! |
66 Posts Member #: 8258 Advanced Member |
11th Mar, 2010 at 09:21:22pm
I would say block it up, you can't have any unfiltered oil entering the engine.
12th Mar, 2010 at 12:34:02pm
Ok, cheers guys! :) Thanks!
12th Mar, 2010 at 05:30:40pm
the usual size is 5/8" UNF hex taperd plug fitted.
Edited by BENROSS on 12th Mar, 2010.
12th Mar, 2010 at 05:51:44pm
I have a turbo oil pump and all new bearings and the oil pressure is very high - about 70 psi hot at 3500rpm.
12th Mar, 2010 at 05:55:18pm
this is only the relief valve in the oil filter,
12th Mar, 2010 at 08:32:23pm
Just make sure the oil filter is changed regulary.
520 Posts Member #: 2093 Post Whore Grenoble, France |
12th Mar, 2010 at 11:11:48pm
Block it. Weld it. This kind of stupid things does not exist on other cars. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
549 Posts Member #: 5327 Post Whore Dudley, West mids |
13th Mar, 2010 at 09:20:49pm
If you want asphalt I would weld yours up free of charge if you could send it me. |
14th Mar, 2010 at 07:46:55pm
On 13th Mar, 2010 madcatminis said:
If you want asphalt I would weld yours up free of charge if you could send it me. Thanks for the offer! :) Much appreciated! I might come back to you if I don't find someone on this of the channel
Cheers, Jan [X] nail here for new monitor |
17th Mar, 2010 at 01:54:12am
On 12th Mar, 2010 alpa said:
Block it. Weld it. This kind of stupid things does not exist on other cars. This exists on every car. It is in the filter body however, not the head. Blocking this off is fine so long as you never operate your engine below freezing and ESPECIALLY if you live in a cold place like canada. If you wonder why, then put a cup of oil in the fridge. Then see how well it flows after a few hours. Then try putting it in the freezer. The oil turns to peanut-butter consistency at this temp - hence won't flow through a filter element either, and hence why by-passes are fitted.
