Home > For Sale > Different Fuse box anda relay box
Metro Turbo Distributor - still installed in the metro van, pic's and vids of the engine running in the build thread. Later 3 pin connector type. dizzy cap and rotor arm are included along with the all important 3 pin plug and wire. SOLD
Power Distribution Fuse box
Fits nicely on the bulkhead between the master cylinders and bonnet hinge (only tried it on a clubman). New and unused.
http://www.polevolt.co.uk/acatalog/info_5026B.html
Polevolt charge just shy of £30, Sold.
Relay box with 4 relays. £10 Sold.
Goodridge braided pre verto clutch hose. Fitted to the metro van but never had fluid in it. Been sat around for a while so the thread is slightly tarnished. Sold.
Edited by apbellamy on 19th Mar, 2010.
Carl S
Member #: 1761
Stalker
I'll take the relay box please Andy.
ill have the fuse box andy ill have to pm you in the morning, got to leave for work now, i can pick it up too if your around
edited*happy*
Edited by Brett on 12th Mar, 2010.
thats a nice fusebox, saved the link, as might use one next time
Yep, I was going run a second loom for all the new bits and bobs on the car from that with the extra relay box. But my TM disease is rife and it's now going to be a completly rewired loom with an mpi/metro style fuse box *oh well*
Everything is sold bar the dizzy, which will be on TMF later this morning.
dizzy sold.
The relay box lid got slightly damaged in the post, so only one side of the lid secures. It will still do it's job fine, but obviously won't be any good upside down or anywhere where moisture is a concern. price reduced to £10 posted.
Also found a second fuse box. one of the lids is crackes, so £10 posted.
relay box sold, fuse box still available
