| Home > Help Needed / General Tech Chat > engine wont turn over after removal/refit | |||||||
12th Mar, 2010 at 09:13:45pm
Iv had the engine out of my mpi cooper this week to sort out some gearbox problems. Hopefully they are now sorted. However, after getting the engine in today I have had a few problems.
12th Mar, 2010 at 09:47:13pm
didnt leave a screw driver in there did you?
12th Mar, 2010 at 09:52:53pm
will pop down tomorrow and have a look. put me in a foul mood though - i didnt even bother going to the pub tonight!
12th Mar, 2010 at 09:53:09pm
Check your earths etc. On 19th Jan, 2010 wil_h said:
12th Mar, 2010 at 09:55:24pm
if the engine is solid get somone to press the clutch while you try turning it,
12th Mar, 2010 at 09:55:26pm
have checked these jason. all good. |
12th Mar, 2010 at 09:57:28pm
yes. the gearbox would turn through the diff to the drops and the other way around. it all seemed to be good. its a fair point though and will add it to the list of thing to check tomorrow mini13. thanks |
12th Mar, 2010 at 10:06:59pm
mini13 i have just ran down to check this, as stated i rekon the gearbox was good when i put it together. as you said though it was disturbed, and was at the back of my mind. the engine wont turn over with the clutch engaged/disengageged so looks good - obviously doesnt rule out gearbox problems entirely but suggests its something else starter related. thanks for the advice |
12th Mar, 2010 at 10:18:10pm
Ok,
12th Mar, 2010 at 10:24:44pm
the engine has been together for about 3000 miles and has eun faultlessly. i havent touched the engine since i put it together. just the gearbox/clutch and flywheel parts/ drop gears.
13th Mar, 2010 at 12:29:54pm
You still havent answered the most basic question.
Edited by stevieturbo on 13th Mar, 2010. 9.85 @ 145mph
![]() 300 Posts Member #: 1746 Senior Member Kent |
13th Mar, 2010 at 12:47:00pm
I would check your main engine earth, and maybe add another...
13th Mar, 2010 at 12:47:47pm
If the engine is locked solid, chances are its one of two things. Long engine mount bolts or long slave cylinder bolts. IIRC the starter motor bolts are the same thread as the slave cylinder bolts but one is longer than the other. On 26th Oct, 2004 TurboDave16v said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
13th Mar, 2010 at 01:19:19pm
earth's On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
13th Mar, 2010 at 01:26:31pm
If it won't physically turn and the starter motor got hot enough to smoke, it is unlikely to be earths.....
13th Mar, 2010 at 01:43:24pm
On 13th Mar, 2010 Rod S said:
If it won't physically turn and the starter motor got hot enough to smoke, it is unlikely to be earths..... Much more likely as Stevie and Sprocket say, wrong length bolts used in the WOK and fouling the flywheel. (starter motor are longer than slave cylinder and for the engine mount, it's easy to accidentally use say a diff side plate one). true.... On 2nd Oct, 2009 Vegard said:
13th Mar, 2010 at 01:54:51pm
If a normal engine ground starp is 99% of the time satisfactory, why would adding another make it any better? If it did, would that not suggest that the original ground strap was not as good and therefore, the problem.
13th Mar, 2010 at 04:41:32pm
hi, only just had chance to log on.
