| Home > Help Needed / General Tech Chat > oil pressure and leak problem | |||||||
549 Posts Member #: 5327 Post Whore Dudley, West mids |
13th Mar, 2010 at 07:41:55pm
Hiya chaps. Right my engine is in a runs like a beaut! Before firing her up I turned her over and was getting 100psi off the starter, so changed the spring back to the standard (was cooper s) and kept the ball bearing. Fired her up and got instant oil pressure. Once running all was good and once warm oil pressure was 40psi then rev'ed and it went to 60psi. The oil at this initial stage was 10-40w.
13th Mar, 2010 at 07:51:28pm
oil pressure sounds fine,
13th Mar, 2010 at 07:52:24pm
also i wouldnrt worry about a few secs for the pressure to come up when cold.
13th Mar, 2010 at 08:03:14pm
I'm worring about the pressure drop when rev'ed now. I've read everything related to 'oil pressure' in the search feature and thinking about an engine strip down is needed. |
13th Mar, 2010 at 08:11:48pm
ah i missed that bit,
13th Mar, 2010 at 08:22:08pm
Oh I didn't know that. I'll pop the plunger in tomorrow. :) |
66 Posts Member #: 8258 Advanced Member |
13th Mar, 2010 at 09:07:14pm
Adjust the oil pressure down from 100psi using the spring you got with the ball valve, it's a bit of trial & error. Shorten the spring a coil at a time until you get near to the pressure you want, then shorten it half a coil at a time etc until you achieve the desired pressure.
14th Mar, 2010 at 09:18:16am
The primary gear is a minta. The engine has done 0miles and only ticking over on my drive. Gonna try the original plunger today so I'll repost later with my findings. |
14th Mar, 2010 at 07:06:07pm
Yeah baby!!! Changed the cooper s ball back to a plunger and all is good. Oil pressure shows on my gauge within 3-5 seconds from cold, and instant from warm.
