Home > Help Needed / General Tech Chat > fuel pump relay
sparkle
Member #: 5544
hi guys, just a quick question- can anyone tell me what current draw there is from a mpi fuel pump so that i can get the right relay, get it wired up and finally get my project mobile? just a bit more bodywork to do then its off to the paint shop. *Clapping* thanks guys
Laurence
Member #: 8258
The fuel pump relay for an MG Metro Turbo is rated @ 40amp which i would imagine is well adequate for the Mpi fuel pump.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Most normal automotive relays will be fine, a fuel pump should only take 2 to 3A.
http://www.twin-turbo.co.uk
Most efi pumps draw an absolute max of 10-15A at high pressure for powerful pumps
On a carb/low pressure install, it probably wuld be less than 5A
Does everyone on here use a relay for the fuel pump?
I currently have one wired in, but im thinking of ditching it to save having to remake the rear loom again, to incorporate some more wires. *oh well*
My switches are rated at 30A so can anyone see a problem not using a relay?
from an electrical point of view, as long as current demand is safe, then the switch is fine.
many people will use a relay to only allow the pump to run under certain conditions though.
Lol Matty, you really need to let the ECU control the pump, then you save on a switch and you won't forget to switch it on:)
I know but, it comes in handy being able to switch off manually sometimes. :)
Johnny
Member #: 6926
Accrington
i have my SPI/MPI tank wired in with a toggle switch (without relay) it is fused at 6amps as my switch is only rated at 6amps MAX and it just has a 12v feed from the battery (just after my battery switch). and this has been fine, doesnt get hot at all and has never blown a fuse.
