| Home > General Chat > engine run in | |||||||
![]() 116 Posts Member #: 4273 Advanced Member stoke on trent |
13th Mar, 2010 at 11:06:29pm
ok whats the best way to run and new built turbo engine in, its got millers run in oil at the mo need do about 100mile be for i change it . is it worth changeing the oil to another 12/50 to get a few more miles on be for i put the good stuff in , thanks nibble:) |
15th Mar, 2010 at 08:19:28am
Search and prepare to got lots of conflicting opinions.... http://www.twin-turbo.co.uk
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
15th Mar, 2010 at 08:22:30am
its the biggest argument of engines. i dont really know how im going to run my engine in. probably get it set up by ear and experiences by bill richards to get the fuelling a needle right. then ill do about 100 miles going up and down the rev range using engine braking. some hard acceleration but onl up to about 4-5k max then at 100 miles ill change oil again and do another 200 miles normal driving and then change oil again to the good stuff On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
869 Posts Member #: 2443 Post Whore Cheshire |
15th Mar, 2010 at 09:20:36am
I followed the reccomendations of Benross, he posted some info on here a while back and have to say it was spot on! do a search and you should find it. |
15th Mar, 2010 at 05:16:42pm
here you go but make sure the timing and fueling are spot on i personall would only run no more than 8psi of boost to brake the engine in http://www.mototuneusa.com/break_in_secrets.htm
15th Mar, 2010 at 05:36:09pm
My engine shop recomendations are not much different to that, and they build lots of high performance engines from Ferrari, through Porsche, to Aston Martin.
15th Mar, 2010 at 06:53:04pm
Ive allways been told if there thrashed from day one they will allways make better power but wont last as long as an engine thats been run in say 500m under 3k then a 1000 up the revs but hardly any boost.
15th Mar, 2010 at 07:06:29pm
As above. The only thing that I have not seen any conflicting opinion on, is to change the oil often. The more the better really, especially in the intial miles.
15th Mar, 2010 at 10:04:41pm
thanks guy will give it a go see what you meen about conflicting opinion in the runing in post about the bike engine :( |
