| Home > General Chat > Front suspension rose joints | |||||||
14th Mar, 2010 at 07:48:19am
Adjustable rose joint front suspension always comes with 1/2"unf rose joints/rod ends, which I am sure is just to make it easier for manufacturers since the bottom arm pin is already 1/2" as standard.
I seriously doubt it! |
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
14th Mar, 2010 at 08:58:13am
just compare there ultimate loads .and yes smaller joints can work just fine,
14th Mar, 2010 at 11:54:14am
Carl, have you ever looked into making aluminium front suspension? I seriously doubt it! |
14th Mar, 2010 at 04:54:02pm
On 14th Mar, 2010 paul wiginton said:
Carl, have you ever looked into making aluminium front suspension? yes, |
14th Mar, 2010 at 06:50:39pm
So why havent you? I seriously doubt it! |
14th Mar, 2010 at 07:29:05pm
So why havent you? i did ,about 13 years ago, bott arms and top arms, |
14th Mar, 2010 at 07:48:43pm
And were they good in use? I seriously doubt it! |
14th Mar, 2010 at 08:43:37pm
can i taker a wild guess?
14th Mar, 2010 at 10:01:07pm
On 14th Mar, 2010 joeybaby83 said:
can i taker a wild guess? would they fatigue under repetitive acceleration/braking/general forces? no problems at all, the top arms were big beefy thick plate, still a whole lot lighter than standard, and the bott arms are onle either in compression of tension and made from a strong enough alloy will be fine, these bott arms were sold on when i rebuilt the Don to a TM member , carl |
14th Mar, 2010 at 11:28:38pm
iirc most of the 5 series front suspension is aluminium Crystal Sound Audio said:
14th Mar, 2010 at 11:32:17pm
A lot of modern cars have alloy suspension and from what I have found lots of upgrades are in aluminium to replace steel OE parts
261 Posts Member #: 713 Senior Member Western Australia |
15th Mar, 2010 at 12:02:02am
A lot of modern cars have alloy suspension and from what I have found lots of upgrades are in aluminium to replace steel OE parts The WRX Sti over the standard Impreza as an example. On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
15th Mar, 2010 at 12:21:24am
I was well impressed by the front end of an E92 335 I was looking at last week. Aluminium front hubs as well as everything else On 12th Nov, 2009 Paul S said:
Gary's description is best |
