| Home > Help Needed / General Tech Chat > clutch plates | |||||||
19th Jan, 2005 at 11:47:12pm
which clutch plate would you guys recommend for road and drag use? i've never even changed a clutch before so i have no idea what to go for, but i'm swapping to pre verto when i take the engine out to fit the cross pin diff as my verto clutch is on the way out and the release bearing is shagged. On 20th Oct, 2015 Tom Fenton said:
20th Jan, 2005 at 12:09:46am
Yes the bolt is different, the verto one is 30mm A/F whereas the early one is 1 1/2" A/F. The late one also uses a integral locking tab thing that is crap, the later one uses a proper locktab.
20th Jan, 2005 at 12:39:33am
Use a Grey with the organic plate.
20th Jan, 2005 at 12:41:47am
cool, i was looking at the road/rally plate so i think thats what i may go for and the grey diaphragm, i'm going to be building another engine for next season with more power hopefully so i might aswell get the grey now.
20th Jan, 2005 at 12:44:46am
ooo more answers. now ive got a conflict....lol
20th Jan, 2005 at 10:46:12am
The drive straps are a fairly weedy bit of spring steel that make the backplate still move when the clutch is deprresed.
339 Posts Member #: 399 Senior Member Austria |
20th Jan, 2005 at 12:48:40pm
Oh shit! I think this is the next mistake at my engine. The clutch was slipping before. Then i build in the grey diaphragm. Now its picking. Damn! Will try to machine the backplate lugs... |
20th Jan, 2005 at 01:28:17pm
picking? You mean slipping?
20th Jan, 2005 at 01:32:08pm
Yes thinking about it 2 does sound right as std
20th Jan, 2005 at 03:15:45pm
I took the flywheel from an old 998...
20th Jan, 2005 at 03:19:47pm
wondering whats a standard vertro clutch capable of holding power wise assuming its in fair condition?
20th Jan, 2005 at 03:44:58pm
well mine was fine on me standard turbo lump, about 2000 miles on my new engine and its knackered, hence the swap to pre verto.
20th Jan, 2005 at 04:07:14pm
No the crank taper is the same for all cranks, so any flywheel will fit. 998 one will be fine.
421 Posts Member #: 245 Senior Member |
20th Jan, 2005 at 05:21:06pm
grey with rally plate works well.no probs at all |
20th Jan, 2005 at 05:36:03pm
sweet! thats saved me a bit of cash then, all i need at the end of the month now then is a grey, a plate and a cross pin diff.
