| Home > Help Needed / General Tech Chat > driveshafts | |||||||
14th Mar, 2010 at 08:55:04pm
does any one know if 1990 998cc manual driveshafts will be the same as 1993 1275 automatic driveshafts?
14th Mar, 2010 at 09:00:37pm
no difference :) On 26th Oct, 2004 TurboDave16v said:
14th Mar, 2010 at 09:02:16pm
im probably wrong, but i thought all auto's used HS shafts? "Turbo's make torque, and torque makes fun"
66 Posts Member #: 8258 Advanced Member |
14th Mar, 2010 at 09:21:53pm
Yes but you can knock off (or grind off |
14th Mar, 2010 at 09:26:11pm
ah, didnt know the shafts were interchangable
14th Mar, 2010 at 09:52:56pm
a 93 auto has pot joints
14th Mar, 2010 at 09:55:56pm
ah, ill unlearn the thing ive just learnt and relearn that then
14th Mar, 2010 at 10:26:46pm
dunno, but I had two 998 autos both A+, one early and one late, and both had pot joints On 26th Oct, 2004 TurboDave16v said:
14th Mar, 2010 at 11:09:58pm
cheers mr sprocket no longer a series, but still 1.3 turbo.
15th Mar, 2010 at 09:07:38am
On 14th Mar, 2010 Sprocket said:
Hardy spicer drive shafts are not interchangeable with pot joint shafts I can verify this. Hardy drivesahfts are the same as rubber ones from Pre73. On 13th Jul, 2012 Ben H said:
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
15th Mar, 2010 at 12:01:25pm
On 14th Mar, 2010 joeybaby83 said:
when was the changeover year? As far as I know they all got the pot joints when they were first introduced. About 1973? [X] nail here for new monitor |
15th Mar, 2010 at 12:25:37pm
What, automatics? "Turbo's make torque, and torque makes fun"
15th Mar, 2010 at 01:39:00pm
On 15th Mar, 2010 joeybaby83 said:
What, automatics? Auto & manual 'boxes got pot joints in '73: http://www.somerfordmini.co.uk/pdfs/Catalo...riveFlanges.pdf [X] nail here for new monitor |
15th Mar, 2010 at 03:02:31pm
oh, when pot joints were introduced? i get you now "Turbo's make torque, and torque makes fun"
15th Mar, 2010 at 03:11:37pm
oh, when pot joints were introduced? i get you now April 73 IIRC. On 13th Jul, 2012 Ben H said:
) the HS coupling & fit a pot-joint if the shafts are identical :)
