| Home > General Chat > Eventful journey home... Opinions | |||||||
20th Jan, 2005 at 07:57:56am
Driving home last night and went round a fairly sharp left hander, one big bang, lots of vibration, swerving across the road and getting it back on the right side to ovoid the on-coming cars, i come to a rest on the verge. |
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
20th Jan, 2005 at 09:45:06am
get back there and tell them to replace both the wheel and the tyre! |
20th Jan, 2005 at 09:59:46am
iain, this is a common fault with MB's there is a new grade of bolt for them, a lot of miglia's had this happen to them, get on to MB! On 15th May, 2009 TurboDave said:
20th Jan, 2005 at 10:05:17am
yeah but shouldnt have caused the tyre to come off the rim should it? the centre wasnt loose at all, plus i wasnt going very quick round the bend anyway, or even pushing it at all.
20th Jan, 2005 at 10:09:15am
well it would cause a very fast deflate, so it may cause the tyre to come off On 15th May, 2009 TurboDave said:
20th Jan, 2005 at 10:32:56am
so when you split the rin from the wheel they deflate? i didnt realise it was that sort of split rim mate, just thought the centre detached from a machined rim.
20th Jan, 2005 at 10:38:43am
the wheels are in 3 pieces, in you take the bolts out, the inside rim, and the outer rim come apart, so you will loose pressure. don't think the tyre place was at fault On 15th May, 2009 TurboDave said:
20th Jan, 2005 at 10:47:41am
damn! so that means MB were? just id had the new tyres fitted, coincidence?
20th Jan, 2005 at 10:51:28am
you should be able to see what I mean from this picture, these are my split rims, you can see that the inner and outer rim is seperate
20th Jan, 2005 at 11:07:17am
What grade are the bolts fitted at the moment? I would have thought they want to be at least 10.9 if not higher tensile?
20th Jan, 2005 at 11:14:24am
not sure but il be getting a full set of new ones from work asap!! best whip one out and see what it is first. |
20th Jan, 2005 at 11:43:43am
How have they failed? It it a brittle fracture or a ductile frature??
20th Jan, 2005 at 11:56:58am
looks brittle to me, might pop a bolt of two up to the lab or bring them in here for an expert eye.
20th Jan, 2005 at 12:14:54pm
A real "brown trouser" moment!!!
20th Jan, 2005 at 12:18:13pm
I'm with you jon, like my wheels to be all one piece!!!
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
21st Jan, 2005 at 05:08:11pm
The rim can easily be repaired by yourself, take a big hammer and hit it carefully but firm. you cant use it now anyway, I have recently repaired my AMG rim this way. It doesn't even vibrate.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
22nd Jan, 2005 at 06:51:14pm
Who built up the rims ? where the rims sealed with some form of sealant ?? They need to be else they will tend to deflate.
23rd Jan, 2005 at 09:11:23am
I had six bolts go at one time on my old one as well.
23rd Jan, 2005 at 10:37:53am
What size bolts are they ???? |
421 Posts Member #: 245 Senior Member |
23rd Jan, 2005 at 11:58:19am
mbs like all splits need to be checked on a regular basis,you cant just fit em and forget em.
24th Jan, 2005 at 11:16:38am
could of been a lot worse |
8 Posts Member #: 405 Junior Member Durham, North East England |
24th Jan, 2005 at 11:34:00am
Sorry to go off topic lads!! Vegard, are they sportpack arches on that dark blue mini you had??
24th Jan, 2005 at 11:35:06am
I was in the workshop last night, there is an MB wheel there which looked exatcly like yours (ie with 4 bolts snapped) I asked Endaf what happened, it was while racing at Spa, nearly killed him, he doesn't use MB's anymore because of this. On 15th May, 2009 TurboDave said:
24th Jan, 2005 at 11:44:21am
Iain I am sure you will be careful but make sure these bolts you get from work are up to the job.
24th Jan, 2005 at 12:25:50pm
On 24/01/2005 11:34:00 NE-Matt said:
Sorry to go off topic lads!! Vegard, are they sportpack arches on that dark blue mini you had?? Matt YEP! On 13th Jul, 2012 Ben H said:
