| Home > Help Needed / General Tech Chat > opinion on my plug colour all four are the same! | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
16th Mar, 2010 at 08:28:12pm
here's the plug, all plugs are a uniform colour matching the one in the pic!
Edited by clubminiflip on 16th Mar, 2010. SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
16th Mar, 2010 at 08:29:32pm
i reckon macro!
16th Mar, 2010 at 08:41:44pm
another vote for macro. |
16th Mar, 2010 at 08:45:48pm
FFS, I have no idea what goes through peoples mind when they post a picture like that then ask advice.
16th Mar, 2010 at 08:58:28pm
Driveway looks nice, I get a lot more moss on mine..... Schrödinger's cat - so which one am I ??? |
16th Mar, 2010 at 09:02:57pm
"OPINIONS" on my plug colour all four are the same AS IN THE PIC! THE PIC IS SHIT WHICH IS WHY I WAS ARSED TO DESCRIBE THE COLOUR IN MORE DETAIL SEE BELOW! which is in the 1st post
16th Mar, 2010 at 09:04:00pm
that driveway is the road at the front of the house!!!! fckin road tax hey! what is it for? SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
16th Mar, 2010 at 09:46:31pm
You need to ditch that clockwork shit and fit your megajolt gear :).
On 16th Mar, 2010 clubminiflip said:
i have to re-check my timing again as its as near as damit to 7/8 degrees btdc at 1500rpm i think it may be better at 6 btdc, the motor is bog-stock! |
66 Posts Member #: 8258 Advanced Member |
16th Mar, 2010 at 10:02:02pm
Are you using the correct grade plug with the correct gap?
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
16th Mar, 2010 at 10:07:56pm
Has Laurence swallowed a Haynes manual? |
16th Mar, 2010 at 11:22:23pm
Like you say check the timing again and give the plugs a clean. If you can get hold of a wideband to borrow then this will show If the mixture is ok. It will at least put your mind at rest that it is fuelling ok I would have said it's hard to get a good idea if it's fueling correctly all the up the rev range by looking at the plug colour? |
17th Mar, 2010 at 12:45:40am
You need to ditch that clockwork shit and fit your megajolt gear!
just have to bolt it in at the weekend & get pipes/tune to make the runs smooth!
