Home > General Chat > Pedal Boxes
n.g.l.
Member #: 181
Chard, Somerset
Are there any differences between the servo and non-servo pedal boxes?
maccamcvey
Member #: 6673
Worral Sheffield
I believe only the brake pedal, you can just get a servo pedal, thing you need to enlarge a hole in the top of the pedal box or/and bulk head.
n.g.l.
Member #: 181
Chard, Somerset
I've got a servo at the moment but want to ditch it in favour of something a little lighter. So you don't think I'll need to change the pedal box then?
The pedal box is the same, the only difference is the hole for the clevis pin in the top of the pedal which you can weld up then redrill the right size
Paul
