| Home > Help Needed / General Tech Chat > bigger brake help | |||||||
82 Posts Member #: 1278 Advanced Member Bedfordshire |
17th Mar, 2010 at 08:31:47pm
Hi just wondering if you guys can help? i am currently running minisport 4pots with 7.9 discs under a set of 10s but i am currently looking at going for a vauxhall engine conversion, i am going to be going for 13s and was wondering if it will be worth upgrading to bigger brakes as i do a lot of trackdays. Any suggestion or ideas on this area will help. |
25th Mar, 2010 at 01:18:22am
bigger 8.4" discS and better pads Own the day
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
25th Mar, 2010 at 10:47:24am
kad k4's £881 cheapr if you contact them and pay cash they will knock the vat off. 10.4 inch discs and fit under 13s and the calipers are 4 pot with dust seals :)
cant beat a good blowout. |
25th Mar, 2010 at 10:52:35am
Joe (Mini13) used Wilwood radial mount calipers, 10.something" discs and had disc bels made up . It worked out cheaper than the KAD setup. The only awkward part was the weird thread for the hose in the caliper. I would go that way if I was upgrading brakes again. On 12th Nov, 2009 Paul S said:
Gary's description is best |
25th Mar, 2010 at 11:32:30am
The question is do you need better brakes? Do they fade are you having stopping problems? A good 7.9 set up should be good enough for most applications. http://www.twin-turbo.co.uk
25th Mar, 2010 at 11:33:52am
Have you read this months minimag? There's several pages by Keith Calver on this very subject. I read it on the train this morning. Safe to say my Metro Vented 4 pots will be going on ebay soon! Edited by apbellamy on 25th Mar, 2010. On 11th Feb, 2015 robert said:
25th Mar, 2010 at 11:34:58am
I appear to have warped my wilwood discs :$ On 28th Aug, 2011 Kean said:
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
25th Mar, 2010 at 12:39:07pm
Any chance you could enlighten us?
On 25th Mar, 2010 apbellamy said:
Have you read this months minimag? There's several pages by Keith Calver on this very subject. I read it on the train this morning. Safe to say my Metro Vented 4 pots will be going on ebay soon! In boost we trust |
25th Mar, 2010 at 12:47:20pm
On 25th Mar, 2010 mini13 said:
I appear to have warped my wilwood discs :$ Haha, well done Joe. How the hell did you manage to warp them? On 12th Nov, 2009 Paul S said:
869 Posts Member #: 2443 Post Whore Cheshire |
25th Mar, 2010 at 12:48:42pm
I appear to have warped my wilwood discs :$ |
25th Mar, 2010 at 01:50:53pm
It basically runs through the efficencys of all the different types of brakes, with positives and negatives for all. The metro 4 pots are generally too strong for the weight of the mini. You are more likely to overwelm your grip with them. And they weigh a tonne.
On 25th Mar, 2010 best_stig said:
Any chance you could enlighten us? Or is it they are overkill for the weight that a mini is? On 25th Mar, 2010 apbellamy said: Have you read this months minimag? There's several pages by Keith Calver on this very subject. I read it on the train this morning. Safe to say my Metro Vented 4 pots will be going on ebay soon! On 11th Feb, 2015 robert said:
25th Mar, 2010 at 01:59:19pm
I'm not quite sure,
25th Mar, 2010 at 02:13:11pm
So does this mean we can solve the disc shield debate and they are there to prevent discs warping from water splashing on the inside? On 12th Nov, 2009 Paul S said:
25th Mar, 2010 at 02:15:28pm
now try thinking about clutch plates gary, mind bottling. "Turbo's make torque, and torque makes fun"
25th Mar, 2010 at 02:20:40pm
26th Mar, 2010 at 02:56:03am
I always figured there were more pistons to stabilize the pad on the disc, so it doesn't judder. In boost we trust |
26th Mar, 2010 at 01:51:06pm
The smaller the diameter of the piston, the further its centre is out from the centre of the disc, hence increasing the lever arm it is using against the disc rotating.
27th Mar, 2010 at 07:01:06pm
This article I will have to read very carefully as I went from the standard twin pot solid disc to the MG Metro 4 pot vented due to brake fade occuring too quickely, basicaly the car got a hell of a lot faster between the corners due to the turbo implant and the brakes could not disserpate the extra energy fast enough. Dont get me wrong here the 4 pots still suffer the same fate but they take one hell of a lot of punishment before they begin to fade.
Have you read this months minimag? There's several pages by Keith Calver on this very subject. I read it on the train this morning. Safe to say my Metro Vented 4 pots will be going on ebay soon! Own the day
27th Mar, 2010 at 07:07:13pm
On 27th Mar, 2010 Mr Joshua said:
This article I will have to read very carefully as I went from the standard twin pot solid disc to the MG Metro 4 pot vented due to brake fade occuring too quickely, basicaly the car got a hell of a lot faster between the corners due to the turbo implant and the brakes could not disserpate the extra energy fast enough. Dont get me wrong here the 4 pots still suffer the same fate but they take one hell of a lot of punishment before they begin to fade. On 25th Mar, 2010 apbellamy said: Have you read this months minimag? There's several pages by Keith Calver on this very subject. I read it on the train this morning. Safe to say my Metro Vented 4 pots will be going on ebay soon! One of the main things that swayed my decision is that they weigh nearly as much as the engine. lol. I will probably end up spending an arm and a leg on some alloy callipers. EDIT:Spelling Edited by apbellamy on 27th Mar, 2010. On 11th Feb, 2015 robert said:
27th Mar, 2010 at 07:09:38pm
Own the day
27th Mar, 2010 at 08:05:57pm
On 26th Mar, 2010 t2clubby said:
The smaller the diameter of the piston, the further its centre is out from the centre of the disc, hence increasing the lever arm it is using against the disc rotating. Some of the Nissan boys are running 12 pot after market jobbies, the pistons are tiny, pushed right out to the edge of the disc. That may be the case but they would almost certainly have a different pad (longer and thinner) shape and probably different discs too (smaller difference between inner and outer radius). If the pad shape was the same, moving the pistons out would only "tip" the pad which I can't imagine would be too sensible. So comparing their performance to the standards doesn't only account for changes in piston area On 12th Nov, 2009 Paul S said:
27th Mar, 2010 at 10:55:21pm
It basically runs through the efficencys of all the different types of brakes, with positives and negatives for all. The metro 4 pots are generally too strong for the weight of the mini. You are more likely to overwelm your grip with them. And they weigh a tonne. Try them before you sell them, I followed his braking advice and im sure I have the worst set up of anyone on here |
27th Mar, 2010 at 11:34:07pm
also, remember that although 7.5" s discs may work for the track where you are slowing down but never stopping they may be inadequate on the road where they need to have the capacity to do an emergency stop without warning.
28th Mar, 2010 at 08:58:13am
The metro 4 pots are generally too strong for the weight of the mini. You are more likely to overwelm your grip with them. And they weigh a tonne. Try them before you sell them, I followed his braking advice and im sure I have the worst set up of anyone on here i agree nic . i dont think its possible to have brakes that are 'too strong'unless you have a wooden foot and st,vitus dance in your leg ...you just do something really really technical to get around the problem ,like for instance ,dont press the pedal so hard ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Mar, 2010 at 09:04:45am
It basically runs through the efficencys of all the different types of brakes, with positives and negatives for all. The metro 4 pots are generally too strong for the weight of the mini. You are more likely to overwelm your grip with them. And they weigh a tonne. Try them before you sell them, I followed his braking advice and im sure I have the worst set up of anyone on here Yes, but I have TM disease. I need shiney light weight parts now. If only carl made Ti calipers... On 11th Feb, 2015 robert said:
