Home > Help Needed / General Tech Chat > megajolt how easy?
masterchief
Member #: 7308
Devon
hi all
im thinking about getting a magajolt to my daily 1032 firstly are they worth it and secondly how long will it take to fit if i have all the bits?
im hoping it will make it start easier and run better, also how easy is it to prgram it to run on a basic get the car running map untill i can start fiddling with it......will it stop it from konkng out in the wet too?
cheers
Definately worth it for a daily. And if you have all the bits together and have built the loom etc it can be installed easily in a day.
There are plenty of maps out there that you can download and use too.
None of it was hard when we fitted it to the van. Nic's guide is an excelent place to start your research.
EDIT:Spelling
Edited by apbellamy on 18th Mar, 2010.
Midas
Member #: 7555
Definitely worth it. Depending on where you are in Devon you could have a look at my install if you want. I'm in East Devon
Carl S
Member #: 1761
Stalker
I'll also be back in Devon (Crediton) very soon if you want to have a look at my setup.
I'm using a V4 MAP MJLJ box.
t@z
Member #: 452
Chester, UK
i think lee and i wired mine up and fitted it in a few hours only problem we had was this
http://www.theminiforum.co.uk/forums/index...topic=91916&hl=
really easy as pie for the wiring i used nics guide
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741
www.twitter.com/lilpinkiy
philc
Member #: 1346
bromsgrove
its well worth it. I am colour blind and i managed it, took me a bit longer but worked first time
Anton
Member #: 764
Staffordshire
Its dead easy, if you have all the bits I did the first time in it in 2 evenings.
But have done it since in a couple of hours.
Well worth it on any engine.
MarkGTT
Member #: 1194
Shropshire.
im a spaz when it come to wiring.. and even i managed it with only minor fuck ups. *happy*
well worth it.
