| Home > Help Needed / General Tech Chat > Hot wires!!! | |||||||
549 Posts Member #: 5327 Post Whore Dudley, West mids |
20th Mar, 2010 at 09:42:44pm
Evening peeps. I've changed my starter motor to the later one with the piggy back solenoid but retained the inner flitch solenoid. I've bridged the two main terminals on the wing solenoid and run another feed from one of the spade connectors to my piggy back. Everything starts and runs, the only thing is that the pink/white wire gets really hot. It runs from the wing solenoid to the plus side of the coil. I have done an extensive search but can't find anything about the 'hot wire' problem..........oh and I'm a mong when it comes to wiring. Any help will be excellent. |
20th Mar, 2010 at 09:47:18pm
its a resistive wire, its supposed to get hot, i assume its only connected to the coil and i assume you dont have electronic ignition. turbo 16v k-series 11.9@118.9 :)
20th Mar, 2010 at 09:53:52pm
yep. Got electronic ignition. My dizzy has a module on the side. I'm also running a lucas dlb198 coil. Edited by madcatminis on 20th Mar, 2010. |
20th Mar, 2010 at 10:26:49pm
The pink/white ballast wire shouldn't run from the (original) solenoid but from the ignition switch or fuse box (depending on year). The only wire from the wing solenoid to the coil was the black/yellow or white/yellow ballast bypass from the extra tag on the solenoid.
21st Mar, 2010 at 03:08:15am
is the pink wire trying to backfeed into the solenoid via the coil? I had a simiklar problem when i changed from pre engaged to inertia starter i cant remember why but the coi l feed was trying to fire the solenoid somewhere ilse in the circuit, everything else was fine other than the pink wire getting very hot
Edited by Brett on 21st Mar, 2010. Yes i moved to the darkside |
21st Mar, 2010 at 06:29:16pm
I've had a good mess this afternoon and found that the pink/white wire starts from the fuse box (no'5) and goes to the wing solenoid. It then joins up with a white/yellow wire and both of these go to the plus side of the coil. Only the pink/white wire gets hot. I'm confused???? |
21st Mar, 2010 at 06:37:18pm
whats the pink wire connected to at the solenoid? iirc it should go there
21st Mar, 2010 at 06:40:52pm
what does iirc mean? Sorry for being thick. |
![]() 539 Posts Member #: 6807 Post Whore York |
21st Mar, 2010 at 06:58:20pm
If I Remember Correctly - iirc |
21st Mar, 2010 at 06:59:44pm
Thanks adcyork. |
21st Mar, 2010 at 09:29:19pm
the pink wire should go straight to the coil, as that is the resistor for the 6v coil
22nd Mar, 2010 at 07:15:00pm
Here's some pictures guys.
Edited by madcatminis on 22nd Mar, 2010. |
22nd Mar, 2010 at 07:47:05pm
Usuall ballast wiring is pink/white from a 12V supply to coil +ve and a yellow/white (or yellow/black) from the auxiliary tag on the solenoid also up to the coil +ve.
Edited by Rod S on 22nd Mar, 2010. Schrödinger's cat - so which one am I ??? |
22nd Mar, 2010 at 07:54:31pm
So all I need to do is ditch the yellow/white wire and wire the pink/white wire straight up to the plus side of the coil. |
22nd Mar, 2010 at 07:55:37pm
And, having just looked closely at the photos, that "bridge" on the wing solenoid is a fire waiting to start.....
22nd Mar, 2010 at 08:03:35pm
On 22nd Mar, 2010 madcatminis said:
So all I need to do is ditch the yellow/white wire and wire the pink/white wire straight up to the plus side of the coil. Yes, ditch the pink/white and yellow/white and run a new wire (preferably white to match the colour factory scheme :) )straight from the fusebox where the pink white currently comes from to the coil +ve. There should then be another wire (usually white) down to one of the tags on the module. As for the solenoid "join" between the two big threaded posts, do not use that small wire... the easist way is just to move the big cable down to the starter onto the same post as the cable from the battery. If the big wires are correct this will put all the big brown wires as well as the heavy cables on one single point. Schrödinger's cat - so which one am I ??? |
22nd Mar, 2010 at 08:04:45pm
Okey dokey. Shall sort out that dodgy bridge. Rod S your a star. |
22nd Mar, 2010 at 08:36:09pm
No problem....
The pink/white wire is connected to a small spade terminal on the solenoid.
