| Home > Help Needed / General Tech Chat > Fuel tank breather on injection | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
20th Mar, 2010 at 10:10:51pm
Hey chaps
20th Mar, 2010 at 11:10:25pm
I energisd the purge solenoid with a spare injector output on the ECU so that it was enabled above 70*C, between 2000 and 2500rpm, 0% throttle (or whatever the lowest throttle position is), above 10kpa and below 40kpa. This basicaly means that the solenoid is only open on normal over run for 500 rpm.
