Home > General Chat > Would these fit a mini?
Andy500
Member #: 2443
Cheshire
Dont know how i came across these but was wondering if they would fit a mini
http://www.bassettwheel.com/legends_mini.html
They do a 13" wheel with a 4" PCD, just not sure on the offset/backspacing?
longy
Member #: 2727
Bicester
not a clue but i like them
1972 998 TURBO SLEEPER
Andy500
Member #: 2443
Cheshire
Look pretty cool dont they, only problem is there not DOT approved!
they will fit,
on a normal 7x13 the back spacing is approx 3.75"
on a sprortspack 6x13 the backspace is also around 3.75"
I think...
Andy500
Member #: 2443
Cheshire
£45 per wheel plus shipping....anybody know of a UK dealer? They would certainly be different!
the price you see in dollers is waht they will end up costing in pounds plus a lilltle chunk more once they have landed here, from the weights they must be steel,
carl
Andy500
Member #: 2443
Cheshire
They look sweeeeeeeeeet in black.........
am i the only one that does not like these?
Andy500
Member #: 2443
Cheshire
Carl, im seriously gonna look in to these but am completely unsure on the backspacing. Would a 13 x 7 with a backspacing of 3" fit on without trouble? or would a 13x8 with a 4" back spacing be better?
Thanks
Andy
the 3£ backspacing wil clear everything on a mini suspension, but it will leave yuo with an offset of somewhere near the 18mm neg mark , ive calculated this allowing for a 6mm outermost lip at the bead, So quite a large neg but not the end of the world, you'll need to trim the front arches for sure,
obviously the 8" wide and 4" backspace will ahve 0 offset , but you can run into clearance on the rear swing arms i beleive,
carl
Edited by fastcarl on 21st Mar, 2010.
Andy500
Member #: 2443
Cheshire
Forgot to add, I have a sportspack shell so already have the rover trimmed arches, do you think they will need further trimming?
Thanks
Andy
Andy500
Member #: 2443
Cheshire
Unless you fancy doing me a deal on a set of your wheels Carl? Something similar to these in price? heheheh
Andy500
Member #: 2443
Cheshire
Just noticed they also do a 13 x 7 with a 3.5" backspacing, does that mean the offset would be zero? If so they shouldnt be to bad from my calcs, especially as some superlights and alleycats etc run an offset of -7.
I could be completely wrong though!
correct, should be 0
carl
that's right Andy,
but 13lbs per wheel?
look ok,
but not my cup of tea,
i like ragged old steel's....lol
My thought as well...
Anchors, lol
Andy500
Member #: 2443
Cheshire
Yeah I know but there still lighter than the original sportspacks i think!
jamz
Member #: 2292
Tool
Herne Bay, kent
these are more deisgned ofr offroad racing. save up and get some of carl *wink*
cant beat a good blowout.
