| Home > General Chat > OT audi A6 Kerbweights | |||||||
21st Mar, 2010 at 11:02:54pm
Odd this one
21st Mar, 2010 at 11:16:44pm
se, i guess the 'e' might be electric pack?
22nd Mar, 2010 at 06:53:01am
SE is just a spec level, but TBH not much difference between the "Sport" and SE.
22nd Mar, 2010 at 09:42:49am
the seats differ between the sport and SE and the suspension is lower but i doubt either would make much differance to the overall weight
111 Posts Member #: 29 Advanced Member Croydon |
22nd Mar, 2010 at 10:53:47am
On some BMWs the M Models (and sometimes the Sport models) had suspension parts in ally, where the std parts are steel..
Too many projects! |
22nd Mar, 2010 at 07:41:33pm
just been on the audi website at the used section; 2002 130 tdi SE avant kerb weight 1540
23rd Mar, 2010 at 10:00:05am
On 22nd Mar, 2010 jpboost said:
On some BMWs the M Models (and sometimes the Sport models) had suspension parts in ally, where the std parts are steel.. 100kg is a pretty big difference though. although if the suspension components are a bit lighter, and the sport wheels are presumably lighter, plus different bumpers.. It could be possible I suppose? They either have ally suspension or they dont.... M cars are different to std models (like an M3) they often has totally different suspension components. AlexF |
23rd Mar, 2010 at 10:00:20am
Why do you need a car over 1600kg? AlexF |
23rd Mar, 2010 at 10:15:22am
i think he ment the msport ones not the M models, the wheels will be heavyer on the se :) Drives
23rd Mar, 2010 at 10:22:37am
On some BMWs the M Models (and sometimes the Sport models) had suspension parts in ally, where the std parts are steel.. 100kg is a pretty big difference though. although if the suspension components are a bit lighter, and the sport wheels are presumably lighter, plus different bumpers.. It could be possible I suppose? They either have ally suspension or they dont.... M cars are different to std models (like an M3) they often has totally different suspension components. Not wanting to take this too far off topic,... but that's not the case, The E30 M3 uses either steel or ally wishbones, depending on the year. These are identical to the steel ones on the std cars. In fact later sports and tourings got the ally arms fitted. As the ally ones are very expensive, plenty of m3 owners run steel arms & change them regularly (if they see a lot of track use) The E34 also had interchangable steel/ally front syspension arms. Some models including the M5 had the ally, basic ones had the steel. It's probably less common on newer models though... Too many projects! |
23rd Mar, 2010 at 12:44:01pm
Back to the original question.
23rd Mar, 2010 at 01:27:37pm
They dont make a quattro in a 1.9 Tom
23rd Mar, 2010 at 02:02:12pm
do you do a lot of miles? |
23rd Mar, 2010 at 02:04:33pm
Didn't know that.
23rd Mar, 2010 at 02:58:35pm
On 23rd Mar, 2010 jpboost said:
Not wanting to take this too far off topic,... but that's not the case, The E30 M3 uses either steel or ally wishbones, depending on the year. These are identical to the steel ones on the std cars. In fact later sports and tourings got the ally arms fitted. As the ally ones are very expensive, plenty of m3 owners run steel arms & change them regularly (if they see a lot of track use) Wishbones on an E30? They don't have any. The closest thing to a wishbone is the track control arm. I have a 318i which has ally track control arms. I have never seen a steel one. And they only cost €90 for a new ally one with the rear bush and both balljoints fitted On 12th Nov, 2009 Paul S said:
Gary's description is best |
23rd Mar, 2010 at 03:02:57pm
On 23rd Mar, 2010 Tom Fenton said:
Didn't know that. Why do you need over 1600kg? Crystal Sound Audio said:
23rd Mar, 2010 at 03:03:49pm
On 23rd Mar, 2010 Rob Gavin said:
23rd Mar, 2010 at 03:19:39pm
On 23rd Mar, 2010 GaryOS said:
Wishbones on an E30? They don't have any. The closest thing to a wishbone is the track control arm. I have a 318i which has ally track control arms. I have never seen a steel one. And they only cost €90 for a new ally one with the rear bush and both balljoints fitted Well seeing as even the BMW parts program (TIS) refers to them as wishbones, I'm not fussed.....I can go and take some pics of the steel ones off my M3 if it helps? FWIW Steel are currently around £45, ally ones about £250. Back on topic. If you need it to be over 1600kg, can you spec the sport with a couple of extra options? (like the rear electric windows etc) 100kg might be a lot of money in options though!! Too many projects! |
23rd Mar, 2010 at 05:59:28pm
On 23rd Mar, 2010 wolfie said:
40k in the last 15 months On 23rd Mar, 2010 Rob Gavin said: do you do a lot of miles? |
