| Home > Help Needed / General Tech Chat > Which pump? | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
21st Jan, 2005 at 01:57:38pm
i fancy using a facet pump (as the ecu can control power to it), which pump should u use?
216 Posts Member #: 370 Reads "my mates" max power whilst wearing my Mrs's underwear |
21st Jan, 2005 at 10:14:21pm
? far as i know every one just uses 12v high pressure pump it needs to run a certain bar pressure or you'll be stuffed, i cant remember the psi rating do a search to find out |
21st Jan, 2005 at 10:15:23pm
why would you want the ecu to control the power what are the benefits ? |
21st Jan, 2005 at 11:24:13pm
On 21/01/2005 22:15:23 turbosteve said:
why would you want the ecu to control the power what are the benefits ? cos it can :) What sort of psi do i need to look for?
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
22nd Jan, 2005 at 08:40:27am
The standard Metro Turbo pump gives 36psi.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
22nd Jan, 2005 at 10:34:17am
No you cant use a facet as they only put out about 4-5 psi of pressure. You need an injection style pump capable of putting out higher pressure than the boost you plan to run. |
84 Posts Member #: 255 Advanced Member |
23rd Jan, 2005 at 06:01:57pm
The difference is in the type of pump:
23rd Jan, 2005 at 06:43:12pm
i'm using a megasquirt2 with the relay board, it simply controls the power to an electric pump, but looks like i'll have to use a metty turbo pump as the leccy ones dont produce enought pressure.
23rd Jan, 2005 at 07:00:29pm
aha! sorry, when you said ecu, the thought was the old metro one. Still think you need a turbo pump, or an injection fuel tank (see elsewhere on the board).
23rd Jan, 2005 at 11:24:19pm
so is the metty turbo one the only choice then?
23rd Jan, 2005 at 11:32:14pm
it works fine so why mess with it??
24th Jan, 2005 at 07:48:18am
Or i can do new bosch ones for ?90 inc P&P
24th Jan, 2005 at 09:09:48am
y iain i was just about to mail u! i'll be grabbing a few other boits off you so i'll mail you soon.
24th Jan, 2005 at 11:29:30am
ang on, why do u need a 36psi pump if u only need 3.5 from the regulators output to the carb?
24th Jan, 2005 at 11:46:38am
You only need 3.5psi as a base setting but that 3.5psi is the pressure the fuel needs to be _ABOVE BOOST_
Edited by Tom Fenton on 24th Jan, 2005.
24th Jan, 2005 at 11:55:51am
ah ha gotcha :)
