Home > Help Needed / General Tech Chat > anyone write C++?
I have to write a bit of C++ code to convert ????? seconds into Hrs:Min:Sec format,
I think I may have cracked it but am not sure the intergers are working as I think they are, I've looked on line for converters but cant find any.
can any one confirm if this looks right?
BadgerBaiter
Member #: 2257
Brighton
I think that looks right to me.
I only just started C++ this semester though, so there is chance I am wrong!
http://www.jolyonway.com
lol i'm only a couple of weeks in too,
cheers!
It's been about 10 years since I wrote any code so I'm very rusty but it looks about right, does it compile & run? The only thing I'm not sure about is whether or not long the correct variable type would integer be better.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
It looks OK to me too. I haven't done any in 3 years though. I'll stare at it for a while longer and see if I get anywhere
On 30th Apr, 2010 Rod S said:
Gary's description is best
BadgerBaiter
Member #: 2257
Brighton
I ve just been made aware that I need to write a specification for a program that I have to write.
We all thought it was due for the end of the week. oops.
Doing a unit conversion program; distance, mass, volume etc etc.
Its due for 8am.
oops.
WTF....
alpa
Member #: 2093
Grenoble, France
remove your last % 60 operation and check instead that seconds are always < 60. If it happens then you messed up.
In theory you could use
assert(seconds < 60)
But assert() is a shit because it makes an abort() of the program, it kills it right away.
Another point: time is never negative, right ? So don't use signed types for it (long is actually long int), especially because % operation gives surprising results on signed values.
In theory you should check the validity of what users have typed as input, in your case they can input a negative number.
Edited by alpa on 23rd Mar, 2010.
The code is correct as far as c++, but as others have said the maths might be wrong. The easyest way to do something like this is to work out the equation on paper with numbers, then translate the numbers into variables, then just move it into your code.
Out of curiosity, why have they got you learing c++? That went out with the arc, you should be doing c# these days. It has proper object orientation and is much much easier to learn (I am a novice at best).
alpa
Member #: 2093
Grenoble, France
apbellamy, most of industrial applications are written in C and C++, especially those sold for more than $1000 per license. When you use some c# or ruby or any other flavor of the the modern trend there is quite often something else running behind your application, and this one was written in C/C++ (I write in C/C++ for living).
Understanding of the C/C++ programming is the base of a good programming in other languages, at least to avoid reproducing common mistakes of the C++ programming.
BadgerBaiter
Member #: 2257
Brighton
i may have to pick your brains in the future Alpa. I apologise in advance :p
Thanks Alpa,
Good point on the unsigned variabes :)
you also made me think about how I was using the modulus function, I have now don the calculations a different way and they seem to be coming out correct, (they wern't before).
if anyone's interested here it is now.
Andy,
I'm leaning C++ as I'm looking to start doing stuff with PIC's in C, apparently they are similar enough to learn either then the other later on.
also the C++ should be useful for interfacing with the pic's from a pc.
or that's what I've been told anyway...
jbelanger
Member #: 831
Montreal, Canada
That definitely looks better (and correct).
Jean
http://www.jbperf.com/
alpa
Member #: 2093
Grenoble, France
Well now that you made the final version: usually you won't do this way because you'll want to translate the wall clock second number (# of seconds from 1970) you got from the system. And you'll do that using standard C functions.
PIC: the crappiest microcontroller I've ever seen. Try using something else if you want to learn, just to know what a MCU should look like. Say 8051 or any Motorola or AVR (Atmel). PICs used to be cheap but I suspect they became more expensive since they won market shares. And they are still a crap.
Carl S
Member #: 1761
Stalker
Here it is in java :)
import java.util.*;
public class SecondsConvert
public static void main(String[] args)
Scanner kybd = new Scanner(System.in);
int secondsIn, secondsOut, minutes, hours;
System.out.println("Please enter the number of seconds to convert: ");
secondsIn = kybd.nextInt();
hours = secondsIn / 3600;
minutes = (secondsIn % 3600) / 60;
secondsOut = (secondsIn % 3600) % 60;
System.out.println("The total time is: " + hours + ":" + minutes + ":" + secondsOut);
jbelanger
Member #: 831
Montreal, Canada
Carl, you don't need the modulo 3600 when computing secondsOut.
Alpa, the Motorola are now Freescale MCUs.
Jean
Carl S
Member #: 1761
Stalker
I wrote that about 2 years ago Jean, I just remembered that I did a similair thing, so cut and pasted it from my old code archive!
It could probably be optimised but it's not much use to me any more :)
alpa
Member #: 2093
Grenoble, France
Yes I know. Philips is NXP, Siemens is Infineon, SGS Thomson is STMicro. Fairchild MOS and Mostec and many others are dead, I've heard that somewhere :) . Intel is still Intel, I wonder why.
Games are all still written in C++, too.
