Home > Help Needed / General Tech Chat > dumping with no valve ?
turbosteve
Member #: 370
Reads "my mates" max power whilst wearing my Mrs's underwear
when my turbo kicks in and then change gear i get a real loud dump valve noise, funny thing is i dont have a dump valve *indifferent*
whats causing this?
minimark
Member #: 19
newcastle
is it the pop off valve in the plenum??
turbosteve
Member #: 370
i really havent got a clue? the car gos ok
minimark
Member #: 19
newcastle
no , there is a pop valve in the plenum, if you have not done anything too it , it`ll be that ,
turbosteve
Member #: 370
its all pretty standard so it must be that cheers
Nick
Member #: 154
Midlands
i thought that thing didnt kick in untill about 10psi or something though? mine did the same before i had a boost gauge or dump valve, turned out the pipe to the actuator was split and it was overboosting.....not good :(
turbosteve
Member #: 370
by the feel of things i think its over boosting, will get it sorted
steve *happy*
there is a popet valve, small dump valve in the plenum budddy
layland, rover, fitted this as an added saftey device for over boost as well as serving for the above it cracks off at around 10psi
i blanked mine off, tapping this to
38"BSP (BRITISH STANDARD PIPE),
the hole left after removing the spring and the guts, happens to be the right dia for the tap to sail straight in
i fitted a hex taperd plug with some PTFE tape on to the seal it .
if you want a plug let me know but i cant send you the tap so you will have to cadge one, 2nd tap is sufficient
but some of the guys have diffrent ways of blanking it off
ie a lot stronger spring or haraldite, Ally weld it or what ever
do away with it or you will never be able to boost over 10psi ISH*frown*
search the threads on this site for "actuators" & "plenums"
BENROSS:*wink*
Edited by BENROSS on 22nd Jan, 2005.
turbosteve
Member #: 370
cheers mate, i plugged the ecu pipe to stop/limit the boost, there must be a split some where, will get a boost gauge to sort it, im gonna leave that popet valve there until i got the readys to get a dump valve.
Nick
Member #: 154
Midlands
yup, ive got my dump valve on my plenum, blocked the standard thing off with a load of 5p's *happy*
i learnt it all the hard way
BOOST GAUGE ON A TURBO MOTOR IS EVERTHING
tried that bud666 but blew them out!
Nick
Member #: 154
Midlands
yup i also learnt that you need a boost gauge and a rolling road setup the hard way.
i'm only running 10psi max on this engine so the 5p's havent gone anywhere yet thankfully *happy*
SumpNut
Member #: 28
I have had 5p's blocking my poped valve for the last 2 and a half years!!! no probs rerported from me!
turbosteve
Member #: 370
that poppet valve sounds a good safety feature, im gonna leave it there, i dont plan to run higher than 10psi.
dan
Member #: 93
i used to get that noise on my 5 turbo and that had no dump valve at all, I was told it was the air travelling back through the turbo (stalling the rotor etc) and out through the air filter......
