| Home > Help Needed / General Tech Chat > changing the diff pin? | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
22nd Jan, 2005 at 03:48:30pm
ok, i will be getting my turbo engine next month when i have the mony for it i am planning on changing a few things to make it that little bit more reliable (oil seals/oil and water pipes etc) |
22nd Jan, 2005 at 05:26:55pm
not too big a job for the diff pin. but.......... when you replace it with an uprated one replace the small roll pin as well for a new one,
22nd Jan, 2005 at 08:28:53pm
thanks for the reply benross, i looked at the cross pin diff, but as it is a 'relitivly' low budget install i cant streatch to 150 quid for it, (and by this i dont eman cutting corners i eman i can live without it) i will change the roll pin as well then, i guess haynes will guide through this? i would check now but its at feebles, lol
22nd Jan, 2005 at 10:34:11pm
Well Dan, me personally believe, the standard vertro clutch is capable of taking 140bhp ISH in standard form if its not shagged out, if you are on a budget see how it goes??? Taking it off can be a ball ach, but do a search on clutches on this site it will put you in the ball park, I fell into this trap my self!
22nd Jan, 2005 at 11:13:27pm
lol, i read the depressing moment about clutches thats whats making me have second thought, i dont know if i want all that stress!!
22nd Jan, 2005 at 11:30:02pm
i think you are on track
Edited by BENROSS on 22nd Jan, 2005.
23rd Jan, 2005 at 08:36:33am
If you change the pin, it's ESSENTIAL that you change the planet gears as well. AND, the bronze washers that lies between the planet gears and the diff housing. If not, the new pin will be worn out after the first corner.
28th Jan, 2005 at 12:26:04am
vegard, sorry to be a pain in the rear, but coudl anyone do a step by step on EXACTLY what i need and what i need to do to change the planet gears as well, having not even seen inside a gearbox before its not much use till i get the engine hear.
28th Jan, 2005 at 01:08:05am
yep. plainit gears and diff etc are all removeable from the diff when the diff is removed from the gearbox (via the diff covers on teh back) :) turbo 16v k-series 11.9@118.9 :)
28th Jan, 2005 at 07:02:15am
On 28/01/2005 00:26:04 pot_dan said:
vegard, sorry to be a pain in the rear, but coudl anyone do a step by step on EXACTLY what i need and what i need to do to change the planet gears as well, having not even seen inside a gearbox before its not much use till i get the engine hear. is this all still posible without taking the engine of the box? thanks, Dan Engine and box out of car 1) lever pot joints out of side of box 2) Remove diff side covers and large diff back cover 3) Diff complete with Crown Wheel will lift out of gearbox 4) Flatten lockwashers and undo 6 bolts to remove crown wheel from diff 5) Punch out aforementioned roll pin that secures the diff pin 6) Drift out diff pin and recover planet wheels and bronze washers 7) Replace diff pin planet wheels and bronze washers. Build back into diff, secure diff pin with new roll pin. 8) Build crown wheel back onto diff. Use new locktabs 9) Replace diff into gear casing. Shim as per Haynes manual. 10) Replace diff cover and side casings. Use new locktabs. Simple as that. Probably a couple of hours job maximum.
28th Jan, 2005 at 06:40:47pm
cool thanks tom, so parts i need to buy are:
