Home > Help Needed / General Tech Chat > What do you think could be the problem??
holmesgraham
Member #: 2556
Southport, Merseyside
I recently finished my project off and got it fired up. I came to try and start it one morning and it turned over alot and then just suddenly locked up solid. I know this question is a bit vague but i just want to know if i'm looking at another engine rebuild. It has only been driven 15 miles! Never been abused. What do you guys think could be the problem? Ive never attempted to rebuld the engine so im not too clued up.
any help will be appreciated!
Wile E. Coyote
Member #: 7893
Portsmouth
Ceased ? Oil ?
Jamie.
Is it locked up or is that the starter cannot turn it?
have you done anything to the engine at all?
if your running jolt, you havent left the dizzy drive in have you?
whats its history?
Andy500
Member #: 2443
Cheshire
Is it forced induction?
What compression ratio?
What battery?
can you turn it by hand witht he plugs out?
flat battery?
Andy500
Member #: 2443
Cheshire
Rockers incorrectly adjusted/come loose
you've recently fitted megajolt haven't you...
did you remove the distributor drive?
Loose starter motor.
MarkGTT
Member #: 1194
Shropshire.
lets hope he did..
Andy500
Member #: 2443
Cheshire
Just out of curiosity and because i dont have and experioence with megajolt etc why do you need to remover the dizzy drive?
if you remove the distributor there is nothing to keep the dizzy drive in position so it can jump up and twat the crank.
it will rattle about and can drop into the engine fouling the crank or potentially mincing the gearbox :(
Andy500
Member #: 2443
Cheshire
Aha makes sense, cheers fellas
Rick.SPI
Member #: 8027
oh dear!
