| Home > Help Needed / General Tech Chat > Advcie on N/A engine | |||||||
35 Posts Member #: 397 Member |
22nd Jan, 2005 at 08:58:34pm
In the summer i did a compression check on my engine and it came out with 100,100,100,70. This seemed really low i was expecting 140-160. |
22nd Jan, 2005 at 09:27:13pm
If the cylinder head has been changed from what was originally fitted to the block u may have the wrong size chambers in the head i.e.too big
22nd Jan, 2005 at 11:39:20pm
Hmmmmmmmmmmmmmmm..........................................
Edited by BENROSS on 23rd Jan, 2005.
23rd Jan, 2005 at 09:04:54pm
not much help now but for future reference after doing a compression test squirt a little oil into the cylinders (trough the sparkplug holes) if your psi readings improve then normally this indicates a ring problem, if they stay the same wet plus dry then normally indicates head or gasket fault. no longer a series, but still 1.3 turbo.
23rd Jan, 2005 at 09:54:11pm
been and had a look at it today, lots of scoring in bores 1 and 4, the pistons feel very loose in the bores aswell. its a 1330 but mileage etc is unknown i think (dave may know)
84 Posts Member #: 255 Advanced Member |
23rd Jan, 2005 at 10:34:22pm
if its not too scored/fecked, clean it, crack test it and take it to 1380, rebuild with a turbo strapped on. If its been thrashed, when you get it out, heave the crank out (you'll have to anyway for the rings) and check the centre main bearing cap and block *edges* as it is quite possible that you'll find a tiny lip where the bearing shells have hammered into the block - not so good. Fecked rings suggest (amongst other things) C/R too high (too *small* chamber/skimmed head/block) or just plain been thrashed. Whats the head casting number and are the pistons dished or flat tops?
