Home > General Chat > bleed valve / boost controller difference?
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
hi
is there any difference between boost controller and bleed valve??
Which one would be the best to use, any comments why?
1.
2.
3.
i am not sure that i will use solenoid, or i should use it? why you need to have option to run 2 different boosts?
may be some one have diagram how to fit them as well ? :)
thank you for help!! :):)
Nothing special!
They are all basically bleed valves. To call them a boost controller....Well, a wastegate actuator is a boost controller too.
chominsh
Member #: 8160
ok, thank you :)
any advice which one better? :)
what kind of controllers are you using??
Nothing special!
chominsh
Member #: 8160
i found hks evc 3 electronic boost controller is it will be better than manual?
any advantages and disadvantages? :)
Nothing special!
Depends what you need or are trying to achieve.
On many applications a simple bleed valve does a very good job. And I'd suspect for most Mini applications...they work perfectly.
An electronic boost controller can be adjusted easily in-car...which is handy. And most generally can offer faster spool up, and better boost control targets.
But again....whether you need faster spool on a fwd car with little traction is debatable.
And it will also depend on how hard/soft the WG is to start with, and how much over this the EBC is actually targetting.
if its very little, then its probably a waste of money.
