| Home > General Chat > Radius Arm Repair Kit | |||||||
18 Posts Member #: 8199 Member |
30th Mar, 2010 at 01:09:04pm
I Bought A Radius Arm Repair Kit, It Has Come And The Copper Bush Doesnt Fit Onto The Bar I Have Read A Manual ANd It Says Something About Reeming Can Anyone Tell Me What Is Meant By This Thanks |
30th Mar, 2010 at 01:12:01pm
Why the ridiculous use of capitals?
30th Mar, 2010 at 01:50:46pm
HeY MaN yOu LeAve hIM AlOne 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
30th Mar, 2010 at 02:42:32pm
At least he is trying to use propper english. Capitalisation aside, there's some punctuation and no text speak. 6/10 On 11th Feb, 2015 robert said:
30th Mar, 2010 at 08:08:49pm
yes you need to ream them out
1050 Posts Member #: 764 Post Whore Staffordshire |
30th Mar, 2010 at 08:09:08pm
30th Mar, 2010 at 08:45:18pm
On 30th Mar, 2010 Anton said:
http://tinyurl.com/y93v7g4
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
30th Mar, 2010 at 08:47:26pm
They need to be reamed to the correct size, yes. To do it properly, you'll need a guided reamer (a tool with 'razors' that basicaly 'shaves' off a thin layer of material, until you have a perfect fit).
http://tinyurl.com/y93v7g4 Holy cow!
Edited by Asphalt on 30th Mar, 2010. [X] nail here for new monitor |
30th Mar, 2010 at 09:08:52pm
as above, ideally use a guide or jig of some sort to do it
30th Mar, 2010 at 09:12:56pm
We had a brass bush to knock in on the needle bearing side as a guide for a extended adjustable reamer. Worked very well & quick enough :) [X] nail here for new monitor |
30th Mar, 2010 at 09:18:00pm
http://tinyurl.com/y93v7g4 excellent ![]() o
on mine i modified a radius arm pin to carry a small flapy paddle wheel, and spun it up with a drill, i had to improvise worked out way better than i thought it would
Yes i moved to the darkside |
