| Home > Non-Mini Discussion > plasma cutter cuts out? | |||||||
160 Posts Member #: 1085 Advanced Member Netherlands |
30th Mar, 2010 at 08:33:00pm
I've been playing with my ESAB MigCut 250/50 today (well, the plasma cutter bit of it anyway; the welder works perfectly fine), cutting the wings off a Mini Van for flipfront purposes. The thing works fine but only for a few secs, then stops. Airflow continues for another few seconds (probably to cool the head down a bit). Only after that's stopped can I resume. I thought you were supposed to be able to cut for a bit longer than just a few secs? Or is this normal on a (semi) professional plasma cutter?
1963 Cooper
5th Apr, 2010 at 11:26:46pm
found the other earth lead at the back of the machine...oops 1963 Cooper
6th Apr, 2010 at 08:57:23am
Yes i moved to the darkside |
7th Apr, 2010 at 11:27:16am
Lol is this one of these inverter jobs off ebay? Ive been scouting these for a whipe but cant make my mind up if theyre shit or not 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
1 Posts Member #: 9667 Junior Member |
4th Nov, 2011 at 04:17:45pm
On 7th Apr, 2010 MikeRace said:
Lol is this one of these inverter jobs off ebay? Ive been scouting these for a whipe but cant make my mind up if theyre shit or not If you get the right one then they're great. |
4th Nov, 2011 at 07:40:26pm
Lol is this one of these inverter jobs off ebay? Ive been scouting these for a whipe but cant make my mind up if theyre shit or not I bought a Giant Cut 40 a couple of weeks ago. They do take a steady hand, but it certainly cuts through metal. Maybe not as neat as some videos might suggest, but I'm sure a lot of that is technique. Ive used it to cut a lot of holes and parts on my front suspension cradle ( Granada ) Some parts are maybe 2-3mm thick and others around 8mm thick. So far I am impressed it does cut with ease, but the holes etc do take a little cleaning up after. The only danger I would see, is they do produce a massive shower of sparks behind the cut. So there are obvious fire risks 9.85 @ 145mph
