| Home > Help Needed / General Tech Chat > oil Temp sender Sealing | |||||||
31st Mar, 2010 at 09:46:38pm
Hi all just wondering what people have used to seal the temp sender. The kit came with a washer with a rubber centre, but it appears to be leaking past the threads. PTFE ?? or is that a no no.
31st Mar, 2010 at 09:52:07pm
Mine & the vans are in the speedo housing. just put them in with a bit of loctite. I guess it depends on the sensor? If something is worth doing, it's worth doing half of. |
1st Apr, 2010 at 05:49:50pm
i have had one of those temp sensors, they do take a bit of sealing, its that crappy washer and O ring PTFE tape with oil is a no no it dont work!
1st Apr, 2010 at 08:23:03pm
mm a bit of a pain. I will try some bearing fit. I run a supercharger and I don't care the TB is on the wrong side.
7th Apr, 2010 at 10:16:51pm
well got it sealed and my attempt at getting an oil temp reading, probably not ideal but I'm getting a reading, which is better than none..
