Home > Technical Chat > Brake Cylinder Bore Clearances
Does anyone know what the clearance is between the rear brake cylinder & the piston? and further does a half inch rear brake cylinder have an internal bore of exactly 0.500 inches or is it more like 0.503 inches to allow for the piston bore clearances?
Edited by Rob H on 1st Apr, 2010.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Sorry Rob, not much help, but IMO there can only be a few thou in it.
New cylinders are only about £8. Can't you just mic one up ?
I'm assuming you don't intend using it for brakes ?!?
Richard.
evolotion
Member #: 83
Glasgow, Scotland
I always thought they were a sloppy fit like near .5mm and any play taken up by the seal. However dobt have one to hand to measure :(
Denis O'Brien.
I can't answer for definate as I've not measured one.
However, normal engineering convention is to make the hole an exact size and put the variation for clearance or interference on the OD of the mating component.
Cheers, I'm toying over machining up some alloy ones to save a bit more weight off the car, god knows if it'll work or not.
alpa
Member #: 2093
Grenoble, France
Usually you need at least 0.05mm to allow oil enter the clearance. As here the goal is to prevent oil passing I'd say you need at most 0.05mm.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Interesting Rob.
With an ali piston and a cast iron cylinder, will it be more susceptible to galvanic corrosion between the dissimilar metals ?
I only ask as we've had a number of problems with actuators on marine turbines where the ali pistons had seized when in long term contact with CI and hydraulic fluid - caused by moisture contam.
Richard.
Edited by turbominivanman on 2nd Apr, 2010.
I was thinking of going for an aluminium piston and an aluminium cylinder, the later is going to push the limits of my tools but I think I can do it.
