Home > Help Needed / General Tech Chat > Slightly OT Spitfire MegaJolt
webba
Member #: 1495
MAP or TPS would you recommend for a standard 1296cc spitfire mk4 running on twin su's (again standard). Thinking MAP initially but feel free to put me right!
Edited by webba on 1st Apr, 2010.
turbominivanman
Member #: 1504
Westbury, Wiltshire
IMO, if you intend keeping the SU's, I'd go for MAP anyday - it's directly showing you what vacuum the engine is pulling and what load site to use for the ignition you need to run.
Richard.
webba
Member #: 1495
Richard.
cheers for advice, i do intend keeping it standard, well apart from a missing dizzy!
Ben H
Member #: 184
Melton Mowbray, Pie Country
Yes, it is only when you have wild cams and throttle bodies that MAP can't be used so effectively. Other than that MAP is the preferred option.
http://www.twin-turbo.co.uk
philc
Member #: 1346
bromsgrove
tps with wild cams
