| Home > Introduce Yourself > Yet another head gasket question! | |||||||
16 Posts Member #: 2838 Member |
4th Apr, 2010 at 06:38:01pm
Finally got the Midget running this weekend only to find my oil decided to turn into cream.
4th Apr, 2010 at 06:44:41pm
Hello
4th Apr, 2010 at 06:50:35pm
Not too much really but enough to show all was not right. Which is why I decided to take the head off and found No1 cylinder full of water. |
4th Apr, 2010 at 07:00:53pm
If there are no cracks inthe head and the gasket has not leaked the only other option seems to be a crack in the bore - not very likely and not a nice thought.
4th Apr, 2010 at 07:28:18pm
did you remove the bottom hose before pulling the head?
Yes i moved to the darkside |
4th Apr, 2010 at 07:30:38pm
Where was the creamy oil?
In the 13's at last!.. Just |
4th Apr, 2010 at 07:31:33pm
Hi, I'm fairly confident that the bores are good. I have a suspicion that the head gasket was not sealing properly but not sure why as yet,
4th Apr, 2010 at 07:33:41pm
On 4th Apr, 2010 Brett said:
did you remove the bottom hose before pulling the head? and are you using duckhams oil? (sp?) always had problems with that oil and rocker cover mayo This is what I'm getting at. Does the gasket look ok? My rocker cover always had Mayo in from condesation and if you don't get all the water out before pulling the head, the bores will fill up. In the 13's at last!.. Just |
4th Apr, 2010 at 07:37:42pm
I'm using Miller's oil. The emulsified oil was all around the rockers and running down the push rods. I haven't drained the sump as yet but I suspect the water has reached there as well. I am going to check that tomorrow. |
4th Apr, 2010 at 07:41:01pm
Sorry but I'm getting my replies a bit out of sinc.
4th Apr, 2010 at 07:48:21pm
Sorry One Eyed Lizard, I just grasped your idea. I hadn't considered that my removing the head was the cause of the water in the bores. I did have emulsified oil arould the rocker area though and when I removed the push rods I had to wipe the "cream" off them.
4th Apr, 2010 at 08:57:01pm
The "cream" often referred to as matonnaise can be simply the result of the engine not being warmed up properly, to boil off the water (condensation) that accumulates. Duckhams oil seems to be particularly prone to this.It will only occur when the car has been used regularly for short runs, which does not seem to be the case in your situation ?. |
66 Posts Member #: 8258 Advanced Member |
4th Apr, 2010 at 09:42:27pm
Take the head to an engine machine shop now that it's off & have it pressure tested, it may be old & porous or someone could have got too close to the waterways when they gas flowed it or it could be cracked.
4th Apr, 2010 at 09:59:15pm
Sounds like there's nothing wrong at all.
4th Apr, 2010 at 11:32:21pm
You may be right, I've just ordered a new BK450, Best I give that go first and if it doesn't work out I'll get the head tested as Laurence suggested. I still think that condensation can't really be the answer. The engine hasn't run for more than an hour tops but I hope I'm wrong on this one. |
5th Apr, 2010 at 12:12:45am
I have often found water contaminated oil in the rocker cover with no apparent water loss when I checked the radiator. If an engine is left sat for a period of time the oil residue in the rocker cover and breathers will soak up moisture.
Own the day
![]() 384 Posts Member #: 4215 Senior Member |
28th Apr, 2010 at 09:18:32pm
HI GUYS....
28th Apr, 2010 at 09:30:37pm
50 lbs 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
28th Apr, 2010 at 10:28:45pm
The Metro Turbo is quoted as 55 ft/lb.
29th Apr, 2010 at 08:33:55pm
thanks guys, saving my ass yet again..
30th Apr, 2010 at 09:24:04pm
i usually do them 50 dry and no retorque. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
