Home > Help Needed / General Tech Chat > Hif carb
AllanMcD
Member #: 414
Dalbeattie Scotland
Hi can anyone help my carb keeps loosing its oil I rebuilt it before I instaled it but the kit didnt have any parts for the oil pot.
http://www.rabdunn.co.uk/
How fast is it using the oil?
And what oil are you putting in it?
AllanMcD
Member #: 414
Dalbeattie Scotland
It is using the oil in around 200 miles I have used the proper su oil and many other oils eg 10/40 15/50 streght 20 - 30 - 40 I work in a motorbike shop so oil isnt a problem.
Edited by AllanMcD on 25th Jan, 2005.
does sound a bit OTT. how much are you filling it up to?
try 20/50?
AllanMcD
Member #: 414
Dalbeattie Scotland
I fill it up to the top of the piston chamber but sometimes after only 100 miles the car has a flat spot and I check the carb and there isnt any damping.
I've not a clue why some carbs tend to lose the oil... It is one of those many mysteries that always will be...
I use the thickest oil I can find - Valvoline 20/50 is my favourite. I found SU damper oil was too light.
SumpNut
Member #: 28
My carb uses a lot of oil even using 20/40 treacle!
I assumed its just worn out after covering its fair share of miles.
On long journeys I often have to stop and refil - especially if they are stop start journeys
akirch
Member #: 399
Austria
My brother had a brand-new HIF6 carb at his n/a engine. This new part lost the oil the first time. A big blue cloud of smoke was abruptly getting out of exhaust and the damper oil was away.
After a few hundred kilometers it was OK. No problems since then. He uses 15/40. Very cryptic! :cool:
http://www.minifreunde.at
