Home > Help Needed / General Tech Chat > blue smoke when engine cold?
jom
Member #: 6003
blue smoke from exhaust when every time starting at moring.. but after 10mins running , oil temp up and smoke gone. spark plugs are good, i think the problem is turbo oil seal. i use 15w50 oil., is it too thin? BY the way, i have a rev limiter same as the pic shows : http://www.lahoutermotorsport.be/images/cm...imiter_-rl4.gif
where are the wires go?
jom
Member #: 6003
problem is solved. all i did is change oil from morris 15w50 oil to halfords 20w50 oil, althought still have some blue smoke when just start engine, but it will disappear second after. I will never use MORRIS oil again!! its just like water.. and i also have some morris 30W oil , it also like water.
i think the thicker oil is just masking a problem, the first does indeed sound like turbo seals, the second the valve stem seals only way to cure it is to fix it properly,
both will just get worse, and in my experience rather fast
jom
Member #: 6003
i saw there're oil around dump valve. but i just done 1000mile after turbo rebuilding
