| Home > Help Needed / General Tech Chat > Wiring Alternator | |||||||
332 Posts Member #: 483 Senior Member Merthyr Tydfil |
6th Apr, 2010 at 08:42:26pm
Hi all Im wiring in my alternator Ive wired the thick brown wire from the starter to terminal B. Another brown wire off the starter slighlty smaller which point does this attach to and the smaller brown and yellow wire? because there are three conections and 2 wires.
160 Posts Member #: 1085 Advanced Member Netherlands |
6th Apr, 2010 at 11:42:45pm
I think you only hook up two out of three. One goes to the ignition light; another to switched +. Maybe this helps: http://westfield-world.com/daihatsu_alternator.html. Plug looks different, but basics are the same. New ones have a little white sticker in the shape of the actual socket with P-IL or some thing like that. 1963 Cooper
7th Apr, 2010 at 12:01:39am
i just ran ignition switched live to the middle, im not arsed about a dash light as i have a voltmeter on the dash "Turbo's make torque, and torque makes fun"
7th Apr, 2010 at 12:32:57pm
Ok so the two brown wires that join as at the starter motor. One will go to terminal B and the other (A) is wired to the middle point I have labelled (2).
7th Apr, 2010 at 08:25:36pm
yeah, all the fat brown wires should go on the battery (B) stud on the alt
7th Apr, 2010 at 09:26:04pm
Ok thanks Joeybaby83 |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
2nd Aug, 2010 at 09:16:17pm
Did you ever get this sorted out properly mate?
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
2nd Aug, 2010 at 09:27:28pm
in turn short them to ground through a bulb, (that way you wont fry anything) one will light the dash bulb and one won't
3rd Aug, 2010 at 09:13:40am
I get that bit just fine Joe, but what I'm unsure about is the fact that BOTH the larger brown wires seem to be live constantly, so the ignition switched live would be on constantly. Doesn't this risk frying something? Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
28th Feb, 2012 at 12:26:39pm
sorry to dig up an old post but i have the same issue with my alternator wiring. I have my big battery feed wire, lamp wire and another permanent live, does this mean i need to run a new ign live from somewhere or will it be ok to connect my permanent live to the connection marked "IG" on alternator? -MINI CLUBMAN 1380 TURBO- |
