| Home > Help Needed / General Tech Chat > Calliper Refurb | |||||||
64 Posts Member #: 4837 Advanced Member Tonbridge Kent |
8th Apr, 2010 at 03:45:36am
Hi Guys
8th Apr, 2010 at 09:29:29am
Should be OK, but I would not like to use a blow torch on that lump of cast iron ! Try compressed air on them first, or seal up the hose entry with a bolt and copper washer, substitute a bleed nipple with a grease nipple and pump grease in from a Wanner or similar -takes some time to fill them up, but the hydraulic pressure is enormous and will usually move those pistons. |
8th Apr, 2010 at 10:26:43am
As above, pumped grease...
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
8th Apr, 2010 at 10:52:15am
I left mine in a bucket of parafin for about 3 weeks (i forgot about them...brought them up a treat though. Like Rod says use a block of wood etc to stop the pistons moving out so as you cant get the next one. I used compressed air to get the pistons out (being as careful as possible) but I knew i was replacing all the pistons and seals On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
9th Apr, 2010 at 03:31:46am
Thanks Guys.
9th Apr, 2010 at 08:18:01am
dont forget to get some red rubber grease for the rebuild Crystal Sound Audio said:
