| Home > Help Needed / General Tech Chat > Cleaning gearbox case | |||||||
10th Apr, 2010 at 10:39:46am
Does anybody have a home brew method of getting the inside of a gearbox clean and gleaming? I've got an empty case I want to clean up before I rebuild the box and I am struggling to find anywhere local to get it cleaned. |
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
10th Apr, 2010 at 11:03:40am
Shove it in the dishwasher if it will fit,sure someones had pictures up of stuff they've popped in there before and it came up reasonably well.
I have a bit of a fetish for tools |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
10th Apr, 2010 at 11:20:57am
Yes an no. The washing dye will corrode the case, mine got dark grey and dull. But proper clean :) I'm not puttin alloy in a dishwasher again. :/
[X] nail here for new monitor |
10th Apr, 2010 at 11:51:10am
Jetwasher and an open field. In the 13's at last!.. Just |
10th Apr, 2010 at 01:44:42pm
Jizer and scotchbrite always does it for me
I seriously doubt it! |
10th Apr, 2010 at 05:18:03pm
de-greaser and a pressure washer worked for me. I did it at a petrol station with their jet wash, but most won't let you do it now On 11th Feb, 2015 robert said:
10th Apr, 2010 at 05:39:44pm
Thanks guys. I have already given it a good go with a jet wash, and that got the worst of it off. I'll give elbow grease a go. |
10th Apr, 2010 at 06:40:02pm
Try brillo pads and another blast out. I guess anything that is good at degreasing and slightly abrasive would work. On 11th Feb, 2015 robert said:
10th Apr, 2010 at 09:08:57pm
scotch brite / brillo in the bath with swarfeager (sp) grease remover top class, gets the bath clean too suprisingly Yes i moved to the darkside |
72 Posts Member #: 6792 Advanced Member |
10th Apr, 2010 at 09:57:46pm
See if you can find someone to soda-blast it. It will take all the gunk, grease, road grime and any paint off, but will not in anyway harm the casting. When asking around be sure to enquire that they do it dry. Some try to do it wet, to keep the dust down but is way less effective so will cost you more to get a result. |
10th Apr, 2010 at 11:27:18pm
i use alloy wheel acid and pressure wash on ally bits no longer a series, but still 1.3 turbo.
