Home > For Sale > UNF AND UNC TAP AND DIE SET FOR A MINI
turbo hogster
Member #: 178
stowmaket suffolk
For sale new UNF and UNC tap and die set for any A series engine. The kit consist of most of the common thread sizes found on the A series engine and gearbox casing.
All Taps are plugs (finishing taps) but starters can be added at extra cost of ?3.00 per Tap.
Kit 1 consists of the following.
? UNF Tap and Die
5/16 UNF Tap and Die
5/16 UNC Tap and Die
3/8 UNF Tap and Die
3/8 UNC Tap and Die
Basic cost is ?33.00
ADDED EXTRAS
Tap holder and Diestocks ?7.00 for the pair.
9/16 parallel hand reamer ?10.00 each
Valve guide setting tool ?5.00 each (specify depth 14.2 for normal cams and rocker ratio, 13.7 recommended for high lift cams and rockers).
3 piece tapping drill set for the above set ?6.00
Can also supply any tap or die or reamers including adjustable please email for price.
Actually postage should only range from ?3 - ?4 depending on what you require.
Please email for postage address, please allow 2 weeks for delivery but should only take a week from receiving cheque.
THE ABOVE TAP AND DIE SET ARE IDEAL FOR CLEANING OUT ALL THE THREADS , BLANK TAPPING INTO CAST IRON WOULD IDEALY BE BETTER USING A HIGHER GRADE TAP THAN THOSE PROVIDED HERE BUT I HAVE USED THEM FOR CAST IRON WORK WITH GREAT CARE, BUT AS SAID IDEAL FOR CHASING THE THREADS.
Email richard@greevesr.fsworld.co.uk
