| Home > General Chat > 18cc piston engine build query + full race head | |||||||
12th Apr, 2010 at 10:15:49pm
hi, i am getting to the point on my project where i need to look at getting an engine together and in. i was going to run a mild turbo motor, as im changing from spi to carb/turbo and mj. i want to make sure i can get it to run before i spend mega bucks on an engine!
12th Apr, 2010 at 10:20:04pm
To be honest, as you already have the head I would be tempted to just use it. It will cost a load to get another one made anyway.
12th Apr, 2010 at 10:46:10pm
Hmmm. Not sure about your calcs. I've got 18cc accralites and 20ccs in the head. My cr is 8.6:1.
In the 13's at last!.. Just |
12th Apr, 2010 at 10:53:16pm
Or if you fancy selling it I may be interested.
12th Apr, 2010 at 10:57:04pm
thanks but i think i will hang onto if for now. i didnt take into account that the pistons sit that .8mm down the bore. what cc does this give with the standard block deck height?
12th Apr, 2010 at 11:17:37pm
0hp at 0psi as it's not been run yet.
13th Apr, 2010 at 07:11:40am
On 12th Apr, 2010 theoneeyedlizard said:
Hmmm. Not sure about your calcs. I've got 18cc accralites and 20ccs in the head. My cr is 8.6:1. What piston to deck clearance are you thinking of? The accralites run 0.8mm down the bore with a std deck height. Either way. I'd also be tempted to use the head you've got. Although the valve sizes are not best suited to fi. have you both got the same capacity engine ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Apr, 2010 at 09:47:59am
Very good point Robert.
13th Apr, 2010 at 03:04:44pm
i make it around the 8.3:1 mark with the .020.
Edited by welshdan on 13th Apr, 2010. |
