Home > Help Needed / General Tech Chat > Can't get the head off the spint **It's off - Cheers**
I have never come across this before, the head is stuck to the block.
Any tips, I've trid big levers and turning it over.
Edited by wil_h on 14th Apr, 2010.
Nick
Member #: 154
Midlands
taken the front centre stud out?
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
it's certainly rost welded to studs, I would try to double bolt studs and try to remove them.
good luck, it's not a pleasant job.
I tried to remove all the studs, gave up after two refused to budge.
Might go back to this tomorrow.
Anton
Member #: 764
Staffordshire
We had one like this once, we bolted the head to an engine crane and lifted it :)
nutter driver
Member #: 47
Not very sunny swanage
other option is a load of rope into the bores before is turned over.... have had to do that once of twice......
Fuck the valves then!
heat the bolts with oxy acet.
Not if you remove the rockers first?
That 3m penetration spray has worked wonders in the past for me.
webba
Member #: 1495
turn engine over with spark plugs in? compression should pop the head - sorry just read youd already turned it over, scrap that then.
tnt down the bores? :)
Edited by webba on 14th Apr, 2010.
Weld the nuts on the top of the two studs that won't budge (they will be scrap anyway if they are corroded) then use an impact gun to unscrew them. It tends to shake the corossion free.
I've only ever had this problem on aluminium cylinder heads and in both cases they were bolts (not studs/nuts) which made life a lot easier. (ie, I knew they were corroded because they wouldn't unscrew without resorting to the impact gun whereas the rest of the bolts just came out normally).
Edited by Rod S on 14th Apr, 2010.
I had this once, there's a thread on it somewhere, I'll have a search later. The problem is most likely to be th front middle stud as the tolerance on that hole is tighter than the rest. I tried everything listed above with no luck. In the end I had to remove the engine and unscrew the head with the stud still in it, obviously not possible if you've got a second stud stuck in there, then once the head was off I goy my machine shop to press the stud out.
I welded nuts to the studs, one stud snapped, but with enough left for a second go.
two studs still stuck in head, will drift them out later.
cheers
