| Home > Help Needed / General Tech Chat > turbo carb restrictor ring? | |||||||
25 Posts Member #: 8858 Member Halifax, west yorks |
14th Apr, 2010 at 06:40:09pm
hi
14th Apr, 2010 at 06:42:51pm
Theres a thread somewhere outlining what is needed to convert an NA carb to turbo FI use. There is also a thread discussing the necessity for a restrictor ring (38mm, I think)
Edited by GaryOS on 14th Apr, 2010. On 12th Nov, 2009 Paul S said:
Gary's description is best |
14th Apr, 2010 at 06:45:34pm
thanks for that! iv found the bit about converting them but i cant find any thing about the restrictor? ill have another look cheers
14th Apr, 2010 at 06:49:11pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=513
Yes i moved to the darkside |
14th Apr, 2010 at 07:05:07pm
ok, im not using a metro plenum! iv modified one off a renault maybe thats causing me some trouble? i havnt touched the timing yet, my aim was to get it running first then advance it. As for fuel pressure, the regulator im using is a second hand one, i was told it was set correct so i thaught maybe it would be some where near right? i forgot to mention when the engine fires up it will rev but only for a few seconds befor cutting out. |
14th Apr, 2010 at 11:21:53pm
You need the retrictor ring in the plenum and the fuel pressure needs to be set to 3.5 psi In the 13's at last!.. Just |
15th Apr, 2010 at 02:32:52am
Whatis pressurising the float bowl? U need a metty plenum idealy Yes i moved to the darkside |
15th Apr, 2010 at 10:11:08am
The restrictor ring is not essential. But you will have one hell of a ballache trying to get enough fuel into it and getting it to run right without it !!!
15th Apr, 2010 at 05:57:38pm
great advice cheers!! ive made a ring and iv managed to get a pressure gauge as well, hopefully it will solve the problem! |
15th Apr, 2010 at 06:03:15pm
when you say what is pressuring the float bowl are you refering to the pipe that increases the fuel with the boost? there is a fitting on the plenum im using to connect the pipe to, so that should work i think? |
15th Apr, 2010 at 07:06:09pm
Why are you causing yourself so much grief when Metro plenums are cheap and easy to source? In the 13's at last!.. Just |
15th Apr, 2010 at 08:11:38pm
Just use an original plenum,l unless you have detailed knowledge on how the thing works.
15th Apr, 2010 at 09:37:55pm
if you search around the forum, for diy plenums, i think you will find with exception to 1 i can think of all have conceded and gone for a metty plenum.
15th Apr, 2010 at 10:25:04pm
thanks for the advce every one! make that 2 people with diy plenums that work. Ive added the restrictor ring and also pressurised the float bowl, now it runs like a dream and it only cost me a fiver!!!!! |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
16th Apr, 2010 at 01:26:39pm
Welldone Rusty , mind posting up some pics ? "So wat we gonna do tonight Brain?"
