| Home > Technical Chat > Dynamic CR vs. octane rating | |||||||
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
15th Apr, 2010 at 01:35:38pm
Hi!
[X] nail here for new monitor |
15th Apr, 2010 at 01:53:56pm
Can you calculate dynamic CR? Isn't it completely dependant on cam, head, valve sizes etc? On 12th Nov, 2009 Paul S said:
Gary's description is best |
15th Apr, 2010 at 05:38:48pm
I think the term 'effectice CR' would be more appropriate (it's still a 'static' calculation). It depends on cam inlet timing & static CR.
Edited by Asphalt on 15th Apr, 2010. [X] nail here for new monitor |
15th Apr, 2010 at 05:55:07pm
http://www.rbracing-rsr.com/comprAdvHD.htm On 26th Oct, 2004 TurboDave16v said:
16th Apr, 2010 at 11:48:52am
Ok, but still nowt about octane... :(
16th Apr, 2010 at 12:31:03pm
In most caces if your cam is 286 or more you will get away with 11:1 on pump gas anything over that and you will need to be adding somthing like CVL or the likes to boost octane,
On 17th Feb, 2009 Rob H said:
