| Home > Help Needed / General Tech Chat > o/t audi a3 2.0 tdi sportsback | |||||||
15th Apr, 2010 at 03:26:06pm
I was driving home the other day in the 3rd lane as you do, then my turbo stopped so no humf, but still drove. Got home turned off then turned on, then it was back to normal. The managment light did not come, so my understanding is that this would not be registered as a fault on the computer?
15th Apr, 2010 at 05:38:03pm
I had the same problem in a 1.9tdi octavia. turbo was on it's way.
15th Apr, 2010 at 05:54:51pm
keith t had a similar issue with his T5 van - I think it was something to do with the variable vane thingamy jig in the turbo seizing up allowing overboosting - he got advised to just give it a good boot now and again to clear it out; it seemed to clear after the ignition was switch off as well
15th Apr, 2010 at 07:54:27pm
thanks for the adivce, someone has mentioned a chemical to put in which gives it a clean? i have no idea |
16th Apr, 2010 at 08:47:21pm
Millers diesel additive from halfrauds @ £12 or less with a trade card! On 5th Sep, 2011 Vegard said:
16th Apr, 2010 at 09:15:23pm
egr is a favourite, remove, clean, and refit, but blocking the vacuum line that actuates it, its an emissions device and your better without. assuming your engine has the vac-operated egr. (struggle to keep track of VAG engien changes)
Edited by evolotion on 16th Apr, 2010. turbo 16v k-series 11.9@118.9 :)
16th Apr, 2010 at 10:35:53pm
i had exactly the same on my A4 turned out to be the MAF not the turbo Crystal Sound Audio said:
329 Posts Member #: 3193 Senior Member Torbay, Devon |
17th Apr, 2010 at 06:40:38am
Hi
17th Apr, 2010 at 08:18:20am
well, i popped back to my mechanic, droped it on the diagnositics, no turbo fault recorded, so taking to a turbo place today for a diagnostics, rather pay £35 than a couple of K for a new engine, so will let you know the outcome. Rec turbo £325 + £125 to fit, not bad i think. |
17th Apr, 2010 at 10:57:20am
well, they have said my turbo intercooler pipe has at some point come off and being fixed with silicone, this may have contributed to the turbo going, however the is fucked. £275 for turbo and 125 to fit + a new turbo intercooler pipe. Nice!!! |
