| Home > Beginners Tech > boots valve | |||||||
![]() 41 Posts Member #: 7902 Member bridgend, south wales |
16th Apr, 2010 at 01:15:00pm
little confused on the boost control valve. i have read many things on here and also read the turbo-minis piece. as im looking at my turbo i can see a pipe coming from the actuator into the turbo then from the turbo a pipe that come and connects to the ecu. isit just a case of putting a y piece off the on that goes to the ecu and put a boost controll valve? sorry i didnt know how to put this haha x |
16th Apr, 2010 at 01:20:07pm
Dump the ecu and put the mbc or bleed valve between the brass fitting on the compressor housing and the actuator.
Edited by theoneeyedlizard on 16th Apr, 2010. In the 13's at last!.. Just |
16th Apr, 2010 at 01:26:03pm
yeh there is two nipples coming out just block one isit and put the bleed valve in between the acuator.
16th Apr, 2010 at 01:44:41pm
That's it. In the 13's at last!.. Just |
