Home > Wanted > After a few bits!
Amp
Member #: 7856
Hey, im looking for:
A set of metro turbo pistons (standard bore)
Restrictor/brass ring from a plenum chamber
Exhaust section from a T2 turbo, preferably uncracked but depending on severity, cracks may be fine! (i know thats wishful thinking but still)
Lightened pre-verto flywheel and backplate
I think that's all for now, will probably think of other bits though :)
Cheers!
Edited by Amp on 5th Jun, 2010.
Amp
Member #: 7856
Also looking for an mg metro cam :)
did you find pistons?
if not i spotted these.
http://cgi.ebay.co.uk/Metro-Turbo-Mini-Pis...=item20b08eaa33
MarkGTT
Member #: 1194
Shropshire.
sorry mate - completely forgot about this.. will have a look asap for you.
Johnny
Member #: 6926
Accrington
A 19 tooth final drive pinion
I might have one, if i do its in another gearbox i just bought so i will need to check that, im taking it apart tuesday so i will let you know.
Amp
Member #: 7856
Mini13 - Yeah already seen them, thanks for the link though! Was a little wary about them as they've been removed but i'll see how it goes
MarkGtt - No worries, whenever you get round to it i'm not in a rush for it!
Johnny - Thanks very much! Let me know when you get round to it please :)
Johnny
Member #: 6926
Accrington
right, i have this one (19/61) 3.2:1
PM me an offer (selling as a pair, not single incase thats what you meant)
i also have a 4pin diff that this FD is attatched to at the moment (Minisport 4pin diff) done 1k miles since new...
Edited by Johnny on 27th Apr, 2010.
Amp
Member #: 7856
I'm now sorted for the diff/FD, now need the front half of a plenum chamber, i don't want to butcher up mine for a dump valve!
Still after turbo pistons too, out of a set of 8 i got 1 good one and 2 "usable" ones...
do you still need a pre verto flywheel, fast carl was selling the one out the don not long back
Amp
Member #: 7856
Cheers Brett, i'd already seen that and was a bit much for me though!
Amp
Member #: 7856
Now i'm after some straight cut drops and a straight cut gearbox! I know they aren't cheap but i have cash for them :)
Still looking for everything above as well.
