Home > Help Needed / General Tech Chat > Keeping a Map on Megajolt
I've finally got round to fiting the megajolt on my car. It's running fine & fired up straight away after not being started since october.
The Megajolt unit was bought secondhand & had a Map already on it, but this isn't suitable for my car.
I have a better Map and can load it onto the Megajolt & it runs a lot better. But everytime I turn the car off & come to start it again it's gone back onto the old Map which came on the Megajolt. How do I keep the new Map permanently/overwrite the old Map on the Megajolt ?
Thanks
Phil.
Kean
Member #: 341
aka T2clubby
South Staffs
What firmware version are you using Phil? In the software there should be a third button by the download/upload buttons that flash the map to memory.
if you dont press this after uploading the map it will clear on power down.
Aaah ! Thanks a lot. I feel a bit stupid now. Yes that button is there. I'll try again. Cheers mate ! :)
Anton
Member #: 764
Staffordshire
as Kean said.... its a common mistake i believe another TM member fell foul of it when Aldon didn't press it and lost the map the had up together on the RR. Might have been Philc?
philc
Member #: 1346
bromsgrove
indeed it was, many words where had
